IIRC this receiver has a IR receiver for the TV1 and a RF receiver for TV2.
I guess the question is why do you want a UHF remote for the first TV? If its a matter of range or obstructions there do seem to be IR repeater products out there that may solve your problem. I saw one the other day (while looking for an RF blaster which apparently does not exist) that converts IR signals into RF and then back again.
WHat does the tab at the bottom of the remote look like on both sides? You c an program TV1 remote for UHF on a 322, but it is a step by step process tht has to be done just right using the menus...
