UHF Remote for TV 1? | SatelliteGuys.US
Ron R
21
Can I use a UHF Remote to control TV 1 with a 322 and 525 receiver? I want to put the receivers in the basement and control them from the TV's on the other floors of the house. I am willing to buy aftermarket remotes if that will work. I have thought about an IR Repeter but would rather stay with UHF if I can. I have 3 receivers I want to control.
I have programmed two of my 522's to work with a UHF Pro remote on tuner 1 and it works great! It will work with either the IR or UHF remote in single mode.
Ron, it can be doen, just need additional remotes and when you do get them you also have to get into the system info and be sure that they are all on a different remote address, which I would quess that you may be familiar with since you already have the 322 and 522. Send me a p.m.if you need the additional UHF remotes.
I WANT MY HDTV (Dish 1000 signal...?)
Splitter
