Unable to receiver sat. 101 | SatelliteGuys.US
eauboy101
Canada
I am having an issue with an h21-200 receiver. I can get a signal from all other sats. except 101. Check pointing and
all is OK. Have reset etc. several times and same issued. Checked access card and noticed that it had browned on the
end as if overheated. Took receiver to a know working site and hooked it up there and the same issue - no sat. 101.
Can someone tell me if this is a receiver issue or a card issue or whatever it may be. Thanks
:welcome to Satelliteguys eauboy101!
What equipment are you using? It could be the lnb is bad. Being in Canada it's possible you are out of the footprint of 101, but I suspect you would also be out of the footprint of the other satellites then.
Sounds to me like its a receiver issue. I would try swapping the bbc on it. I've seen the bbc stop birds before but if you've tried 2 locations I'd say the receiver is prolly bad.
Directv sats
Erie,PA WICU
