Uncle from Canada | SatelliteGuys.US
Uncle from Canada
DishDave
898
9
He wants to bring his BEV system down from Toronto to Tampa,Fl Will he be able to get a signal down here on a dish 500 ?
He will be staying for a month..
82 will be very marginal with a 20 inch dish.
The Nimiq 3 transponders on 91 won't be availble either.
I do have 5 fingers and toes so i should be able to count that high :(
For some reason I thought there was another crippled bird at 91W as well - so they had 2 Directv rejects.
Honestly, I dont watch their SD channels so I havent checked them since the change so you might be (or probably are) are right.
For point of reference, I have a .9 Meter Toroidal and my signal using a BEV 6000 as reference:
82W
TP 3/1 3/4 3/17
01 91 91 90
02 81 82 83
03 91 88 88
04 UNABLE TO TUNE
05 88 97 95
06 00 00 00
07 66 88 80
08 00 00 83
09 88 97 94
10 00 00 00
11 66 89 81
12 00 00 86
13 89 88 87
14 84 83 84
15 88 87 87
16 87 85 85
17 87 88 86
18 82 81 81
19 86 86 86
20 85 83 84
21 89 89 88
22 82 00 00
23 87 85 86
24 00 84 84
25 87 96 93
26 83 82 82
27 86 85 75
28 86 81 82
29 00 97 93
30 82 82 83
31 00 88 80
32 83 80 84
Given that my Dish 500 averaged about 55 on 148W and now is 75 with the .90, I would suspect that the signal would be in the 60s for most of these transponders in the Tampa Bay area.
Should work ok with a few glitches and fast fade if it rains.
This was first attempt at 82/91 on the white cable and 110/119 on the black cable.
Spectrum Analyzer in the background.
I need to take a more recent shot as everything is well populated now.
Iceberg said:
Nimiq3 is at 82 now so he should get all channels on 91
Ice, I have to assume that D2 @91W is supplying a number of the Odd transponders signals. I have to believe that the D2 footprint is about as uneven as N3 was in the 91W position.
I am actually getting less transponders than before:
91W
TP S
1 44
2 87
3 00
4 93
5 00
6 84
7 00
8 93
9 00
10 93
11 00
12 93
13 43
14 80
15 43
16 80
17 00
18 94
19 44
20 80
21 00
22 71
23 00
24 90
25 00
26 91
27 41
28 76
29 44
30 79
31 13
32 81
At first I *assumed* maybe the odd side of my lnb was bad, but as I have a signal on 1,13,15,19,27,29 and 31 - I don't think that is the case.
Regardless, I do not think his uncle will get "all the 91W" channels if I am getting these readings in the area with a .90M dish.
Multi Receivers on BEV/DISH
CableCARD and Satellite Sercive
