Under Eve Antenna Mount | SatelliteGuys.US
man00
SatelliteGuys Guru
123
100
I have about a 30" roof overhang and I want to mount the antenna there. Anyone seen that type of mount around for not too many $$$ ?
If you have a gable end on your roof take a look at a standard eave mount. It is intended to be screwed into the fascia board, and does not extend under the soffit all the way to the wall.
TV antenna, my house has hip roof. I guess I should have said want to mount the antenna under the overhang to extend out past the roof, the overhang is roughly 30"
We've gone off the rails here a bit - he wants to install a TV antenna not a Satellite antenna.
With the setup here you can install an antenna also. I used an old satelite mount to install a led barn lite on my tv tower and it works just fine
