Nice condition! No "backup" battery needed, (holds memory) 100 channel scanner and 20-channel AM/FM memory.
External speaker jack, terminals for AM antenna (loop AM antenna included.) Also includes adapter from BNC to "f"
to connect to standard UHF/VHF antenna for better reception. S.A.M.E. encoding and Weather ALERT, too! This one's got many features and is highly rated! $70 plus priority (or your choice of carrier) shipping of 3.5 lbs in continental U.S. PM with Zip code for total and/or more info!
<tbody>
[TD="bgcolor: #FFFFCC, colspan: 2"] FREQUENCY RANGE
[/TD]
[TD="bgcolor: #FFFFCC"] Amateur Band (10 Meters) [/TD]
[TD="bgcolor: #FFFFCC"] VHF Low Band [/TD]
[TD="bgcolor: #FFFFCC"] Amateur Band (6 Meters) [/TD]
[TD="bgcolor: #FFFFCC"] Aircraft Band [/TD]
[TD="bgcolor: #FFFFCC"] Military Land Mobile [/TD]
[TD="bgcolor: #FFFFCC"] Amateur Band (2 Meters) [/TD]
[TD="bgcolor: #FFFFCC"] VHF High Band [/TD]
[TD="bgcolor: #FFFFCC"] Federal Government [/TD]
[TD="bgcolor: #FFFFCC"] Amateur Band (70 cm) [/TD]
[TD="bgcolor: #FFFFCC"] UHF Standard Band [/TD]
[TD="bgcolor: #FFFFCC"] UHF T Band [/TD]
[TD="bgcolor: #FFFFCC"] 800 Band [/TD]
[TD="bgcolor: #FFFF80"] AM Broadcast Band [/TD]
[TD="bgcolor: #FFFF80"] FM Broadcast Band [/TD]
</tbody>
(And yes, it's funny that this goes "on" just after another scanner sells....Been thinking of doing this awhile. I don't use this much, even at work in the radio station! It needs a good home...and was going to put here last week, but wondered if it would have an audience. Hope it does!)
29.0- 29.7 MHz |
29.7- 50.0 MHz |
50.0- 54.0 MHz |
108-137 MHz |
137-144 MHz |
144-148 MHz |
148-174 MHz |
406-420 MHz |
420-450 MHz |
450-470 MHz |
470-512 MHz |
806-956 MHz [Less cellular] |
520-1720 kHz |
88-108 MHz |
<tbody>
[/TD]
</tbody>
