Quick question:
Friend of mine gave me a FortecStar Universal Single LNBF FSKU-V
Here are the specs:
R.F= 10.7-12.75 Ghz
L.O= 9.75/10.60 GHz
N.F=0.4 dB
I am under the impression that the LNB has a 22mhz switch built in that switches between bands (to provide a wider spectrum than a standard KU LNB) Is that correct?
If so, that would mean that I couldn't use a external 22mhz switch to combine sats back to one (or more) receivers? i.e. have to use a disqec switch
Thinking about using it for Telstar 12 just to mess around while my CM dish is still in the garage. I later plan on using it for a stationary dish at G10R, but since all I have is 22mhz switches, I'd like to avoid mulitple runs to the store
Thanks!
Here are the specs:
R.F= 10.7-12.75 Ghz
L.O= 9.75/10.60 GHz
N.F=0.4 dB
Thanks!
