unsure about hd equipment | SatelliteGuys.US
godzooky
16
i'm about to (finally) take the plunge and get hooked up with HD. is there any difference between equipment? i see best buy has a HD dish for around $50, but crutchfield has one for around $130. there also seems to be a few different HD receivers. are any of them better than another? my tv has a dvi input, i don't know if that makes a difference for the equipment i buy.
thanks
Just call Directv and order through them, anything you get will now be leased, you can't buy equipment outright. Directv should install the newest AT9 5 LNB dish for you and lease you the H20 receiver and/or HR10-250 DVR depending on what you want. Check the stickies at the top of the main Directv forum for the lease pricing structure.
Mankato, MN locals now available on Direct
BC/Vil HD GAme
