Update on VOOM Box Software | SatelliteGuys.US
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
103,696
29,420
Newington, CT
FYI The following was posted by Wilt to the Yahoogroup regarding the upcoming software upgrade.
Okay, this is not a promise but rather the current schedule based on a discussion yesterday afternoon;
Code push, assuming testing continues to go well, could begin as early as mid-next week and more likely the week after.
Tuning time should be a bit better,
Map behavior should be a lot better--eliminating "factory resets",
Odd pop up behavior should be gone,
Generally more stable,
Box no longer boots to720p,
A number of other things.
Scanning didn't make it this time, looks like April for that.
I have had more problems with the new box than the old box, not an auspicious start. I hope the software drop brings stability again.
Tim
note the HDTV part..Voom could lead or blow it
Where's VOOM in all of this?
