Updated transponder lists? | SatelliteGuys.US
mika911
45
Hi
Does anyone have updated transponder lists? My HD channels (the national cable ones) are always going out and this new HR20 doesn't automatically default to the transponder you're watching, when you do a signal test like the TiVos did, so I don't know which sats/transponders I've having issues with.
Thanks!
Nobody know? I try to watch wimbledon on ESPN 2 HD and it just pixelates on me constantly and audio goes out. I don't know which sat and transponder to even check.
Lyngsat
Hi
Thanks!
Go to www. lyngsat.com and click on HD and it will give you a summary of all HD feeds. Hope this helps
Unfortunately, the TP that is being used is not listed.
These lists could be difficult to maintain since DirecTV can change TP assignments.
Cleveland spotbeam coverage?
New Channel 274!
