I am told they have resolved that issue. And also that issue only involved a small number of receivers out there.Is the "your system may no longer get updates" an issue with the beta program?
My understanding is that the "Add channel" option (or button) is completely GONE !! MikeD will be pretty upset....They have modified the OTA information slightly. I wish tney would allow you to manually add channels but I realize that is an invitation fora gripe session.
I can't imagine why. After all it's been there and posted not available yet for nearly 4 years....My understanding is that the "Add channel" option (or button) is completely GONE !! MikeD will be pretty upset....
OK, thanks Hall. I am going to wait till it comes down to us thru the normal nitely update.You still have to force the update. Do it the same way as before (play, play, recall).
Sent from my HTC One M9 using Tapatalk
I'm confused - I've read conflicting info about the H2K and the Carbon UI. I forced my HWS to download the update but now it doesn't talk to the H2K where half of my recordings are. Does anyone know for sure whether or not we should be able to get the update for the H2K? I've tried - many times.
Limited time offer
