upgrade question | SatelliteGuys.US
upgrade question
NEWCOMER
5
I finally took the plunge to upgrade my 811 & 625 to 622 and keep my 811 for a spare tv. Here is my question...
currently, my HDTV is hooked up to the 811 downstairs. The two tv are hookup to the 625 upstairs. In the new configuration, I plan on hooking up the 622 to the HDTV and one of my tv's upstairs and move the 811 to the 3rd tv upstairs.
Is it easy to do the "rewiring"? Will the installer do this for me as part of the upgrade? All the cables are supposively route through a "box" in the basement.
I gather you own the 811
The installer will be able to re-route the 'TV2 out' back up the same cable feedng the vip622. As long as all the cables from the different rooms meet in a junction box, you're all set, just make sure the installer knows exactly what you want.
yes...i think they all terminate in the junction box in the basement...maybe with one exception...the tv i plan on using with the 3rd receiver (811).
no i don't own the 811...but dish told me that i can just upgrade the 625 and keep the 811 for the 3rd tv.
622 DPP44 install from hell
Did anyone get there feb bill yet ?
