hello, 9 and 3/4 years ago I installed all my directv equipment (I had to pay for everything, there was no such thing as free multiroom installation), which included sony dual lnb dish, 2 in 4 out powered multiswitch. The two cables run from the dish to the multiswitch with direct runs to 3 receivers, the tv with the tivo receiver has two cables connected for the additional tivo options. Since the install everything has worked perfectly. I had all sony equipment, of the 3 original receivers I have upgraded one receiver to a non hd tivo receiver. and another receiver is an HD receiver but it is connected to a regular TV.(gasp)
Anyway eventually I will get an HD TV and I will need to upgrade my dish. I just have some questions on what I will need to do to upgrade, especially regarding the wiring. It is my understanding that I would need a 5 LNB dish. I have seen one for sale and the description states that the dish has a built in 4-way multiswitch.
1. Basically how many cables will have to run from the dish to the inside of my house?
2. since the dish has a multiswitch does this mean that each cable from the dish will have to be a direct run to each receiver? if yes I cannot do this without re-wiring and I will not do that again. Logistically that is out of the question.
3. can I run the cables from the dish to a bigger multiswitch? if yes does the multiswitch need to be powered. my old multiswitch is powered, when I first did the install a passive multiswitch did not work well so if it is better to use a powered multiswitch that is no problem.
4. believe it or not I grounded the dish and cable when I did the install, the two cables run from the dish to a grounding block that have two long copper wires connected which run to a water pipe that runs into the concrete wall of the house. the two cables that are connected to the grounding block run into the house. anyway I live is S Fla where there is lots of lightening so, back then this was a concern. I have seen professional installs and no one seems to ground anything anymore, is this still a concern?
5. the two cables from the dish actually run as follows: dish-->grounding block-->inside the house to a paanamx dbs surge protector with modules designed for protecting Sat cables-->2 in 4 out powered multiswitch-->receivers. how would this configuration need to be changed requiring the least amount of re-wiring.
I am in no rush to get HD, I still feel the TVs are overpriced and I think that after next Feb, prices may drop plus I am waiting for a technology that addresses all the initial complaints about HD quality. ( I am also waiting for my old Mits TV to break)
I just want to know if you think that in the very near future will cables from the dish be consolidated, are there some improvements coming in the near future that will not require so many cables run into the house? I mean I can wait until next year if there are exciting improvements coming.
any information is appreciated.
Regards,
rainfade
PS-please do not suggest that I let Directv do the upgrade, I have never seen an install done better than mine, I know they are not going to use silicone filled connectors outside plus rubber boots to protect against rain. they will not do the little things that mean a lot, like connect the cables to the wall and not let them just hang there, dangling from the outside of the house.
Regards,
rainfade
