Is there a way to had a second drive or replace the existing drive with a much larger size? I know this may have been asked already, just trying to get quicker results.
an SATA drive in an Esata enclosure with a cable plugged into the back of the HR20 or HR21. I believe all you do is Reset everything and the unit will format the external drive and use that drive. But you will have to set your series link all over again and you will not have access to previous recordings on the internal drive.So how do you go about attaching it to the system? Just connect it and you are good to go? Is the connection located in the back of the HR-21? Does it require any formatting or just PNP?
Thanks,
no esata port on the backYes I found out that you are talking about an external encloser type. Do they connect via USB?
an external esata cable from an sata drive in an enclosure like the ANtec MX-1 http://www.newegg.com/Product/Product.aspx?Item=N82E16817371008&Tpk=mx-1You are talking about a external sata driver? Not one that you normally used internally in a pc. Correct?
thanks again
thanks again
I use two of these for my HR20s, and have had zero problems in over a year. They also make them in a 1tb version.
Seagate Free Agent Pro 750gb:
Seagate 750GB FreeAgent™ Pro External Hard Drive at Staples®
careful Ive heard some of the prepackaged external solutions do not work. I think you are much better off with the MX-1 and selecting your own drive.
FAP's don't work on HR21's.
Hmmm,
I've seen you say that previously, but I seem to have seen others say that they do work on the HR21's.
Just another reason to NOT get a HR21
jimbo
Well its half a DVR for one thing with no OTA tuners. I have one of each. And of course I had to spend 50 bucks for an AM21.What is wrong with the HR21's? Are the 20 that much better?
Thanks,
OTA = Over The AirCan you explain a little more about what you are talking about. What is a OTA?
Limited time offer
