uplink 11/11/09 | SatelliteGuys.US
uplink 11/11/09
It actually might be an issue with the uplink pc. My wife says its on, but I can't connect to it from remote, so possibly a network issue.
It will be up as soon as I can get it up. :)
I thought Digi was the keeper of the uplink PC.
We moved it while I was moving homes to Scott's PC. I haven't been able to set it back up yet since I waiting on my buddy to build my bracket so I can bolt a dish to the cement slab out back.
I need to run a line over to the Dish1000 and call it done for now.
I should have it up by then hopefully. My wife reset the machine and its running, but again cant access from remote. Sounds like maybe a network cable or network card issue. :)
Wait... I do have the line connected from the Dish.... I could snag the report but the changes will be from 9/30 till now.. you'll have to weed through a month of changes to see todays. I'll post here in a bit.
FYI... I didn't rename Echo6 to Nimiq5 on myside, so the name will be wrong.
SatelliteGuys.US DishNetwork Uplink Activity Report - 11/11/2009 3:48pm - 370 changes
Uplink Comparison Range: 09/30/2009 02:59P - 11/11/2009 03:43P
Channel Additions:
5612 - KTBY [MPEG4 HD] added to Ciel-2 129W TP 09 Spotbeam 1 (NA)(Anchorage, AK-FOX)
5184(20) - WTXX [MPEG4 HD] added to Echostar12 61.5W TP 01 Spotbeam 3 (A) (H)(Waterbury, CT-CW)
6363(50) - WDCW [MPEG4 HD] added to Echostar12 61.5W TP 05 Spotbeam 4 (A) (H)(Washington, DC-CW)
5655 - KITV [MPEG4 HD] added to Ciel-2 129W TP 16 Spotbeam 55 (A) (H)(Honolulu, HI-ABC)
5659 - KGMB [MPEG4 HD] added to Ciel-2 129W TP 16 Spotbeam 55 (A) (H)(Honolulu, HI-CBS)
5663 - KHNL [MPEG4 HD] added to Ciel-2 129W TP 16 Spotbeam 55 (A) (H)(Honolulu, HI-NBC)
5667 - KHON [MPEG4 HD] added to Ciel-2 129W TP 16 Spotbeam 55 (A) (H)(Honolulu, HI-FOX)
5671 - KFVE [MPEG4 HD] added to Ciel-2 129W TP 16 Spotbeam 55 (A) (H)(Honolulu, HI-MY)
5674 - KHET [MPEG4 HD] added to Ciel-2 129W TP 16 Spotbeam 55 (A) (H)(Honolulu, HI-PBS)
5270(25) - WEHT [MPEG4 HD] added to EchoStar8 77W TP 13 ConUS beam (NA)(Evansville, IN-ABC)
5271(44) - WEVV [MPEG4 HD] added to EchoStar8 77W TP 13 ConUS beam (NA)(Evansville, IN-CBS)
5272(14) - WFIE [MPEG4 HD] added to EchoStar8 77W TP 13 ConUS beam (NA)(Evansville, IN-NBC)
5273(7) - WTVW [MPEG4 HD] added to EchoStar8 77W TP 13 ConUS beam (NA)(Evansville, IN-FOX)
7369(19) - WAZE [MPEG4 SD] added to EchoStar8 77W TP 13 ConUS beam (NA)(Evansville, IN-N/A)
7371(12) - WNIN [MPEG4 SD] added to EchoStar8 77W TP 13 ConUS beam (NA)(Evansville, IN-N/A)
9317(51) - WAGV [MPEG2 SD] added to EchoStar10 110W TP 12 Spotbeam 10 (NA)(Harlan, KY-N/A)
9317(51) - WAGV [MPEG4 SD] added to Echostar12 61.5W TP 07 Spotbeam 6 (NA)(Harlan, KY-N/A)
7372(31) - WKOH [MPEG4 SD] added to EchoStar8 77W TP 13 ConUS beam (NA)(Owensboro, KY-PBS)
5274(38) - WNOL [MPEG4 HD] added to Ciel-2 129W TP 10 Spotbeam 50 (NA)(New Orleans, LA-CW)
5109 - KDNL [MPEG4 HD] added to Anik F3 118.7W TP 11 ConUS beam (A) (H)(St.louis, MO-ABC)
5110 - KMOV [MPEG4 HD] added to Anik F3 118.7W TP 11 ConUS beam (A) (H)(St.louis, MO-CBS)
5111 - KSDK [MPEG4 HD] added to Anik F3 118.7W TP 18 ConUS beam (A) (H)(St.louis, MO-NBC)
5112 - KTVI [MPEG4 HD] added to Anik F3 118.7W TP 18 ConUS beam (A) (H)(St.louis, MO-FOX)
6424(32) - KRCW [MPEG4 HD] added to EchoStar10 110W TP 29 Spotbeam 44 (A) (H)(Salem, OR-CW)
6387(33) - KDAF [MPEG4 HD] added to EchoStar10 110W TP 31 Spotbeam 21 (A) (H)(Dallas, TX-CW)
6387(33) - KDAF [MPEG4 HD] added to Echostar12 61.5W TP 15 Spotbeam 17 (A) (H)(Dallas, TX-CW)
6419(16) - KONG [MPEG4 HD] added to EchoStar10 110W TP 04 Spotbeam 45 (A) (H)(Everett, WA-N/A)
6418(22) - KMYQ [MPEG4 HD] added to EchoStar10 110W TP 04 Spotbeam 45 (A) (H)(Seattle, WA-MY)
5292(46) - WVVA [MPEG4 HD] added to EchoStar8 77W TP 32 ConUS beam (NA)(Bluefield, WV-NBC)
6555(14) - WLFB [MPEG4 SD] added to EchoStar8 77W TP 32 ConUS beam (NA)(Bluefield, WV-N/A)
5294(53) - WSWP [MPEG4 HD] added to EchoStar8 77W TP 32 ConUS beam (NA)(Grandview, WV-PBS)
5291(59) - WVNS [MPEG4 HD] added to EchoStar8 77W TP 32 ConUS beam (NA)(Lewisburg, WV-CBS)
5290(50) - WOAY [MPEG4 HD] added to EchoStar8 77W TP 32 ConUS beam (NA)(Oak Hill, WV-ABC)
125 - ITV2 [MPEG2 SD] added to EchoStar11 110W TP 01 ConUS beam (NA)
125 - ITV2 [MPEG2 SD] added to EchoStar3 61.5W TP 10 ConUS beam (NA)
274 - DISH [MPEG2 SD] added to EchoStar11 110W TP 03 ConUS beam (A)
274 - DISH [MPEG4 SD] added to EchoStar8 77W TP 12 ConUS beam (A)
487 - PLBYE [MPEG4 SD] added to Echostar6 72.7W TP 19 ConUS beam (A)
488 - PLBY [MPEG2 SD] added to EchoStar7 119W TP 04 ConUS beam (A)
488 - PLBY [MPEG4 SD] added to Echostar6 72.7W TP 19 ConUS beam (A)
489 - PLBY [MPEG4 SD] added to Echostar6 72.7W TP 19 ConUS beam (A)
490 - ASHOW [MPEG2 SD] added to EchoStar11 110W TP 10 ConUS beam (A)
490 - ASHOW [MPEG4 SD] added to Echostar6 72.7W TP 09 ConUS beam (A)
492 - REAL [MPEG4 SD] added to Echostar6 72.7W TP 21 ConUS beam (A)
494 - JUICY [MPEG2 SD] added to EchoStar7 119W TP 04 ConUS beam (A)
495 - RKTV [MPEG2 SD] added to EchoStar11 110W TP 03 ConUS beam (A)
495 - RKTV [MPEG4 SD] added to Echostar6 72.7W TP 09 ConUS beam (A)
496 - HUSLR [MPEG2 SD] added to EchoStar7 119W TP 16 ConUS beam (A)
496 - HUSLR [MPEG4 SD] added to Echostar6 72.7W TP 11 ConUS beam (A)
497 - HUSLR [MPEG4 HD] added to Ciel-2 129W TP 18 ConUS beam (A)
497 - HUSLR [MPEG4 HD] added to EchoStar3 61.5W TP 31 ConUS beam (A)
498 - XTSY [MPEG2 SD] added to EchoStar7 119W TP 14 ConUS beam (A)
498 - XTSY [MPEG4 SD] added to Echostar6 72.7W TP 21 ConUS beam (A)
499 - ASHOW [MPEG2 SD] added to EchoStar11 110W TP 10 ConUS beam (A)
499 - ASHOW [MPEG4 SD] added to Echostar6 72.7W TP 09 ConUS beam (A)
531 - PPV [MPEG4 SD] added to Echostar6 72.7W TP 31 ConUS beam (A)
533 - PPV [MPEG4 SD] added to Echostar6 72.7W TP 31 ConUS beam (A)
573(83) - NBALP [MPEG2 SD] added to EchoStar11 110W TP 06 ConUS beam (A) (H)
573(83) - NBALP [MPEG4 SD] added to EchoStar3 61.5W TP 25 ConUS beam (A) (H)
604 - KINOE [MPEG2 SD] added to Echostar12 61.5W TP 21 ConUS beam (A) (H)
703 - FTVTW [MPEG2 SD] added to Anik F3 118.7W TP 29 ConUS beam (NA)
792 - JAYA [MPEG2 SD] added to Anik F3 118.7W TP 06 ConUS beam (A)
4828 - TMP58 [MPEG4 HD] added to EchoStar7 119W TP 10 ConUS beam (NA)
4828 - TMP58 [MPEG4 HD] added to Echostar6 72.7W TP 03 ConUS beam (NA)
4829 - TMP59 [MPEG4 HD] added to EchoStar7 119W TP 10 ConUS beam (NA)
4829 - TMP59 [MPEG4 HD] added to Echostar6 72.7W TP 03 ConUS beam (NA)
4830 - TMP60 [MPEG4 HD] added to EchoStar7 119W TP 10 ConUS beam (NA)
4830 - TMP60 [MPEG4 HD] added to Echostar6 72.7W TP 03 ConUS beam (NA)
4831 - TMP61 [MPEG4 HD] added to EchoStar7 119W TP 10 ConUS beam (NA)
4831 - TMP61 [MPEG4 HD] added to Echostar6 72.7W TP 03 ConUS beam (NA)
4832 - TMP62 [MPEG4 HD] added to EchoStar7 119W TP 10 ConUS beam (NA)
4832 - TMP62 [MPEG4 HD] added to Echostar6 72.7W TP 03 ConUS beam (NA)
4833 - TMP63 [MPEG4 HD] added to EchoStar7 119W TP 10 ConUS beam (NA)
4833 - TMP63 [MPEG4 HD] added to Echostar6 72.7W TP 03 ConUS beam (NA)
4834 - TMP64 [MPEG4 HD] added to EchoStar7 119W TP 10 ConUS beam (NA)
4834 - TMP64 [MPEG4 HD] added to Echostar6 72.7W TP 03 ConUS beam (NA)
4835 - TMP65 [MPEG4 HD] added to Ciel-2 129W TP 30 ConUS beam (NA)
4835 - TMP65 [MPEG4 HD] added to EchoStar3 61.5W TP 32 ConUS beam (NA)
5293(8) - WVNSD [MPEG4 HD] added to EchoStar8 77W TP 32 ConUS beam (NA)
5575(162) - VH1 [MPEG4 HD] added to Ciel-2 129W TP 06 Spotbeam 55 (A) (H)
5740 - IAD11 [DATA] added to Echostar6 72.7W TP 07 ConUS beam (A)
5742 - IAD12 [DATA] added to Echostar6 72.7W TP 07 ConUS beam (A)
5772 - IAD3 [DATA] added to Echostar6 72.7W TP 07 ConUS beam (A)
5773 - IAD4 [DATA] added to Echostar6 72.7W TP 07 ConUS beam (A)
6525(19) - WZMQ [MPEG2 SD] added to Ciel-2 129W TP 12 Spotbeam 15 (NA)
6801 - UPSD [MPEG2 SD] added to Echostar12 61.5W TP 17 ConUS beam (NA)
6812 - UP4 [MPEG2 SD] added to EchoStar7 119W TP 10 ConUS beam (NA)
6855 - UP10 [MPEG4 HD] added to EchoStar8 77W TP 32 ConUS beam (NA)
9619 - BTVT [SD TV] added to EchoStar3 61.5W TP 10 ConUS beam (NA)
36852 - DNL11 [143] added to Echostar6 72.7W TP 03 ConUS beam (A)
Channel Removals:
7384 - WTXX (A) (H) removed from Echostar12 61.5W TP 01 Spotbeam 3(Waterbury, CT-CW)
8074 - WDCW (A) (H) removed from Echostar12 61.5W TP 05 Spotbeam 4(Washington, DC-CW)
6459 - WXYZ (A) (H) removed from Anik F3 118.7W TP 04 ConUS beam(Detroit, MI-ABC)
6460 - WWJ (A) (H) removed from Anik F3 118.7W TP 04 ConUS beam(Detroit, MI-CBS)
6461 - WDIV (A) (H) removed from Anik F3 118.7W TP 05 ConUS beam(Detroit, MI-NBC)
6462 - WJBK (A) (H) removed from Anik F3 118.7W TP 05 ConUS beam(Detroit, MI-FOX)
6453 - KDNL (A) (H) removed from Anik F3 118.7W TP 11 ConUS beam(St.louis, MO-ABC)
6454 - KMOV (A) (H) removed from Anik F3 118.7W TP 11 ConUS beam(St.louis, MO-CBS)
6455 - KSDK (A) (H) removed from Anik F3 118.7W TP 18 ConUS beam(St.louis, MO-NBC)
6456 - KTVI (A) (H) removed from Anik F3 118.7W TP 18 ConUS beam(St.louis, MO-FOX)
6483 - WSOC (A) (H) removed from Anik F3 118.7W TP 08 ConUS beam(Charlotte, NC-ABC)
6484 - WBTV (A) (H) removed from Anik F3 118.7W TP 08 ConUS beam(Charlotte, NC-CBS)
6485 - WCNC (A) (H) removed from Anik F3 118.7W TP 09 ConUS beam(Charlotte, NC-NBC)
6486 - WCCB (A) (H) removed from Anik F3 118.7W TP 09 ConUS beam(Charlotte, NC-FOX)
6465 - WTVD (A) (H) removed from Anik F3 118.7W TP 10 ConUS beam(Durham, NC-ABC)
6467 - WNCN (A) (H) removed from Anik F3 118.7W TP 12 ConUS beam(Goldsboro, NC-NBC)
6466 - WRAL (A) (H) removed from Anik F3 118.7W TP 10 ConUS beam(Raleigh, NC-CBS)
6468 - WRAZ (A) (H) removed from Anik F3 118.7W TP 12 ConUS beam(Raleigh, NC-FOX)
8404 - KDAF (A) (H) removed from Echostar12 61.5W TP 01 Spotbeam 16(Dallas, TX-CW)
6522 - WVVA (NA) removed from Anik F3 118.7W TP 14 ConUS beam(Bluefield, WV-NBC)
6524 - WLFB (NA) removed from Anik F3 118.7W TP 14 ConUS beam(Bluefield, WV-N/A)
6525 - WSWP (NA) removed from Anik F3 118.7W TP 14 ConUS beam(Grandview, WV-PBS)
6521 - WVNS (NA) removed from Anik F3 118.7W TP 14 ConUS beam(Lewisburg, WV-CBS)
6520 - WOAY (NA) removed from Anik F3 118.7W TP 14 ConUS beam(Oak Hill, WV-ABC)
148 - ESPNU (A) removed from EchoStar7 119W TP 04 ConUS beam
148 - ESPNU (A) removed from Echostar6 72.7W TP 23 ConUS beam
220 - DISH (A) removed from EchoStar11 110W TP 03 ConUS beam
220 - DISH (A) removed from EchoStar8 77W TP 12 ConUS beam
485 - ASHOW (A) removed from EchoStar11 110W TP 10 ConUS beam
485 - ASHOW (A) removed from Echostar6 72.7W TP 09 ConUS beam
486 - ASHOW (A) removed from EchoStar11 110W TP 10 ConUS beam
486 - ASHOW (A) removed from Echostar6 72.7W TP 09 ConUS beam
487 - TEEZ (A) removed from Echostar6 72.7W TP 09 ConUS beam
488 - REAL (A) removed from EchoStar11 110W TP 03 ConUS beam
489 - PENT (A) removed from Echostar6 72.7W TP 21 ConUS beam
490 - ALOCK (A) removed from EchoStar7 119W TP 17 ConUS beam
490 - ALOCK (A) removed from Echostar6 72.7W TP 21 ConUS beam
491 - JENNA (A) removed from EchoStar7 119W TP 16 ConUS beam
491 - JENNA (A) removed from Echostar6 72.7W TP 11 ConUS beam
492 - XCESS (A) removed from Echostar6 72.7W TP 11 ConUS beam
494 - REAL (A) removed from EchoStar11 110W TP 03 ConUS beam
495 - PENT (A) removed from EchoStar7 119W TP 04 ConUS beam
495 - PENT (A) removed from Echostar6 72.7W TP 21 ConUS beam
496 - XTSY (A) removed from EchoStar7 119W TP 14 ConUS beam
496 - XTSY (A) removed from Echostar6 72.7W TP 21 ConUS beam
497 - PLBY (A) removed from EchoStar7 119W TP 04 ConUS beam
497 - PLBY (A) removed from Echostar6 72.7W TP 19 ConUS beam
498 - PLBYE (A) removed from EchoStar11 110W TP 03 ConUS beam
498 - PLBYE (A) removed from Echostar6 72.7W TP 19 ConUS beam
499 - PLBY (A) removed from EchoStar7 119W TP 04 ConUS beam
499 - PLBY (A) removed from Echostar6 72.7W TP 19 ConUS beam
604 - KINO (A) (H) removed from EchoStar3 61.5W TP 14 ConUS beam
856 - UTLSM (NA) removed from EchoStar11 110W TP 16 ConUS beam
5381 - TMP16 (NA) removed from Ciel-2 129W TP 18 ConUS beam
5381 - TMP16 (NA) removed from EchoStar3 61.5W TP 31 ConUS beam
5993 - INFO6 (NA) removed from EchoStar11 110W TP 06 ConUS beam
6085 - HISTI (NA) removed from EchoStar11 110W TP 01 ConUS beam
6085 - HISTI (NA) removed from Echostar6 72.7W TP 11 ConUS beam
6086 - BIO (NA) removed from EchoStar11 110W TP 05 ConUS beam
6086 - BIO (NA) removed from Echostar6 72.7W TP 03 ConUS beam
6087 - BIO (NA) removed from Ciel-2 129W TP 29 ConUS beam
6087 - BIO (NA) removed from EchoStar3 61.5W TP 16 ConUS beam
6088 - HMC (NA) removed from EchoStar11 110W TP 01 ConUS beam
6088 - HMC (NA) removed from Echostar6 72.7W TP 01 ConUS beam
6089 - HMC (NA) removed from Ciel-2 129W TP 29 ConUS beam
6089 - HMC (NA) removed from EchoStar3 61.5W TP 16 ConUS beam
6090 - ID (NA) removed from EchoStar11 110W TP 09 ConUS beam
6090 - ID (NA) removed from Echostar6 72.7W TP 03 ConUS beam
6091 - VS. (NA) removed from EchoStar11 110W TP 21 ConUS beam
6091 - VS. (NA) removed from Echostar6 72.7W TP 05 ConUS beam
6092 - VS. (NA) removed from Ciel-2 129W TP 29 ConUS beam
6092 - VS. (NA) removed from EchoStar3 61.5W TP 16 ConUS beam
6093 - GAC (NA) removed from EchoStar11 110W TP 11 ConUS beam
6093 - GAC (NA) removed from Echostar6 72.7W TP 05 ConUS beam
6094 - FUSE (NA) removed from EchoStar7 119W TP 02 ConUS beam
6094 - FUSE (NA) removed from Echostar6 72.7W TP 05 ConUS beam
6095 - WE (NA) removed from EchoStar7 119W TP 12 ConUS beam
6095 - WE (NA) removed from Echostar6 72.7W TP 15 ConUS beam
6096 - IFC (NA) removed from EchoStar7 119W TP 06 ConUS beam
6096 - IFC (NA) removed from Echostar6 72.7W TP 15 ConUS beam
6097 - CI (NA) removed from EchoStar11 110W TP 19 ConUS beam
6097 - CI (NA) removed from EchoStar8 77W TP 13 ConUS beam
6098 - AMC (NA) removed from EchoStar7 119W TP 08 ConUS beam
6098 - AMC (NA) removed from Echostar6 72.7W TP 09 ConUS beam
6099 - LMN (NA) removed from EchoStar11 110W TP 02 ConUS beam
6099 - LMN (NA) removed from Echostar6 72.7W TP 09 ConUS beam
6100 - LMN (NA) removed from Ciel-2 129W TP 23 ConUS beam
6100 - LMN (NA) removed from EchoStar3 61.5W TP 20 ConUS beam
6155 - LTD18 (NA) removed from EchoStar11 110W TP 06 ConUS beam
6523 - WVNSD (NA) removed from Anik F3 118.7W TP 14 ConUS beam
9589 - LTD9 (NA) removed from EchoStar3 61.5W TP 25 ConUS beam
9899 - ITMP1 (NA) removed from EchoStar3 61.5W TP 18 ConUS beam
19101 - PAPA (A) removed from EchoStar11 110W TP 14 ConUS beam
Channel Moves:
8115 - WMBC [MPEG4 SD] moved from Echostar12 61.5W TP 01 Spotbeam 3 to Echostar12 61.5W TP 07 Spotbeam 3 (A) (H)(Newton, NJ-N/A)
8117 - WFME [MPEG4 SD] moved from Echostar12 61.5W TP 01 Spotbeam 3 to Echostar12 61.5W TP 07 Spotbeam 3 (A) (H)(West Milford, NJ-REL)
8116 - WRNN [MPEG4 SD] moved from Echostar12 61.5W TP 01 Spotbeam 3 to Echostar12 61.5W TP 07 Spotbeam 3 (A) (H)(Kingston, NY-IND)
119 - BIO [MPEG4 SD] moved from Echostar6 72.7W TP 03 ConUS beam to Echostar6 72.7W TP 07 ConUS beam (A)
173 - DISW [MPEG4 SD] moved from Echostar6 72.7W TP 03 ConUS beam to Echostar6 72.7W TP 07 ConUS beam (A)
192 - ID [MPEG4 SD] moved from Echostar6 72.7W TP 03 ConUS beam to Echostar6 72.7W TP 07 ConUS beam (A)
204 - TRU [MPEG4 SD] moved from Echostar6 72.7W TP 03 ConUS beam to Echostar6 72.7W TP 07 ConUS beam (A)
205 - FXNWS [MPEG4 SD] moved from Echostar6 72.7W TP 03 ConUS beam to Echostar6 72.7W TP 07 ConUS beam (A)
207 - CNBCW [MPEG4 SD] moved from Echostar6 72.7W TP 03 ConUS beam to Echostar6 72.7W TP 07 ConUS beam (A)
209 - MSNBC [MPEG4 SD] moved from Echostar6 72.7W TP 03 ConUS beam to Echostar6 72.7W TP 07 ConUS beam (A)
261 - EWTN [MPEG4 SD] moved from Echostar6 72.7W TP 03 ConUS beam to Echostar6 72.7W TP 01 ConUS beam (A)
302 - HBOSG [MPEG4 SD] moved from Echostar6 72.7W TP 03 ConUS beam to Echostar6 72.7W TP 01 ConUS beam (A)
304 - HBO2W [MPEG4 SD] moved from Echostar6 72.7W TP 03 ConUS beam to Echostar6 72.7W TP 01 ConUS beam (A)
311 - MAX-W [MPEG4 SD] moved from Echostar6 72.7W TP 03 ConUS beam to Echostar6 72.7W TP 09 ConUS beam (A)
329 - TMC-W [MPEG4 SD] moved from Echostar6 72.7W TP 03 ConUS beam to Echostar6 72.7W TP 09 ConUS beam (A)
330 - TMCXW [MPEG4 SD] moved from Echostar6 72.7W TP 03 ConUS beam to Echostar6 72.7W TP 09 ConUS beam (A)
340 - ENCOR [MPEG4 SD] moved from Echostar6 72.7W TP 03 ConUS beam to Echostar6 72.7W TP 09 ConUS beam (A)
351 - STRZW [MPEG4 SD] moved from Echostar6 72.7W TP 03 ConUS beam to Echostar6 72.7W TP 09 ConUS beam (A)
387 - CI [MPEG4 HD] moved from EchoStar8 77W TP 13 ConUS beam to Echostar6 72.7W TP 17 ConUS beam (A)
401 - GOLF [MPEG4 SD] moved from Echostar6 72.7W TP 03 ConUS beam to Echostar6 72.7W TP 09 ConUS beam (A)
406 - SETA [MPEG2 SD] moved from EchoStar3 61.5W TP 14 ConUS beam to EchoStar3 61.5W TP 10 ConUS beam (A)
409 - CSNCA [MPEG4 SD] moved from Echostar6 72.7W TP 03 ConUS beam to Echostar6 72.7W TP 09 ConUS beam (A) (H)
411 - PRIME [MPEG4 SD] moved from Echostar6 72.7W TP 03 ConUS beam to Echostar6 72.7W TP 01 ConUS beam (A) (H)
437 - SPSOU [MPEG4 SD] moved from Echostar6 72.7W TP 03 ConUS beam to Echostar6 72.7W TP 01 ConUS beam (A) (H)
471 - SPORT [MPEG2 SD] moved from EchoStar3 61.5W TP 08 ConUS beam to EchoStar3 61.5W TP 18 ConUS beam (A)
546 - HDPPV [MPEG4 HD] moved from EchoStar8 77W TP 32 ConUS beam to Echostar6 72.7W TP 27 ConUS beam (A)
547 - HDPPV [MPEG4 HD] moved from EchoStar8 77W TP 32 ConUS beam to Echostar6 72.7W TP 27 ConUS beam (A)
548 - HDPPV [MPEG4 HD] moved from Echostar6 72.7W TP 17 ConUS beam to Echostar6 72.7W TP 27 ConUS beam (A)
549 - HDPPV [MPEG4 HD] moved from Echostar6 72.7W TP 17 ConUS beam to Echostar6 72.7W TP 27 ConUS beam (A)
576 - ZEESA [MPEG2 SD] moved from Echostar12 61.5W TP 21 ConUS beam to EchoStar3 61.5W TP 14 ConUS beam (A)
583 - RADIO [MPEG AUDIO] moved from Echostar12 61.5W TP 21 ConUS beam to EchoStar3 61.5W TP 14 ConUS beam (A) (H)
584 - SAMAY [MPEG2 SD] moved from Echostar12 61.5W TP 21 ConUS beam to EchoStar3 61.5W TP 14 ConUS beam (A)
585 - AAJTK [MPEG2 SD] moved from Echostar12 61.5W TP 21 ConUS beam to EchoStar3 61.5W TP 14 ConUS beam (A)
588 - BLUE [MPEG2 SD] moved from EchoStar3 61.5W TP 18 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A) (H)
589 - ANTGO [MPEG2 SD] moved from EchoStar3 61.5W TP 18 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A)
598 - RBTI [MPEG2 SD] moved from EchoStar3 61.5W TP 18 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A) (H)
599 - SICNO [MPEG2 SD] moved from EchoStar3 61.5W TP 29 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A) (H)
606 - BBCAR [MPEG2 SD] moved from EchoStar3 61.5W TP 14 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A) (H)
613 - TVASA [MPEG2 SD] moved from EchoStar3 61.5W TP 18 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A) (H)
617 - ZCINE [MPEG2 SD] moved from Echostar12 61.5W TP 21 ConUS beam to EchoStar3 61.5W TP 14 ConUS beam (A)
619 - B4U [MPEG2 SD] moved from Echostar12 61.5W TP 21 ConUS beam to EchoStar3 61.5W TP 18 ConUS beam (A) (H)
624 - SHARA [MPEG2 SD] moved from Echostar12 61.5W TP 21 ConUS beam to EchoStar3 61.5W TP 18 ConUS beam (A) (H)
643 - ARTMV [MPEG2 SD] moved from EchoStar3 61.5W TP 10 ConUS beam to EchoStar3 61.5W TP 14 ConUS beam (A) (H)
652 - KBS [MPEG2 SD] moved from EchoStar3 61.5W TP 18 ConUS beam to EchoStar3 61.5W TP 10 ConUS beam (A) (H)
665 - ZIKR [MPEG AUDIO] moved from Echostar12 61.5W TP 21 ConUS beam to EchoStar3 61.5W TP 18 ConUS beam (A) (H)
673 - MZIKA [MPEG2 SD] moved from Echostar12 61.5W TP 21 ConUS beam to EchoStar3 61.5W TP 18 ConUS beam (A)
767 - ABUDA [MPEG2 SD] moved from Echostar12 61.5W TP 21 ConUS beam to EchoStar3 61.5W TP 18 ConUS beam (A)
769 - DREAM [MPEG2 SD] moved from Echostar12 61.5W TP 21 ConUS beam to EchoStar3 61.5W TP 29 ConUS beam (A)
778 - NBN [MPEG2 SD] moved from EchoStar3 61.5W TP 14 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A)
779 - NEWTV [MPEG2 SD] moved from EchoStar3 61.5W TP 14 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A)
842 - UTLSM [MPEG2 SD] moved from EchoStar10 110W TP 29 Spotbeam 49 to EchoStar11 110W TP 16 ConUS beam (A)
912 - RYTHM [MPEG AUDIO] moved from EchoStar3 61.5W TP 18 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A) (H)
913 - SSPFM [MPEG AUDIO] moved from EchoStar3 61.5W TP 18 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A) (H)
914 - NT105 [MPEG AUDIO] moved from EchoStar3 61.5W TP 14 ConUS beam to EchoStar3 61.5W TP 29 ConUS beam (A)
915 - ERA-5 [MPEG AUDIO] moved from EchoStar3 61.5W TP 14 ConUS beam to EchoStar3 61.5W TP 29 ConUS beam (A) (H)
916 - ERASP [MPEG AUDIO] moved from EchoStar3 61.5W TP 18 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A) (H)
4152 - CBS C [MPEG4 HD] moved from EchoStar8 77W TP 13 ConUS beam to Echostar6 72.7W TP 17 ConUS beam (A) (H)
4194 - GREEN [MPEG4 HD] moved from EchoStar8 77W TP 13 ConUS beam to Echostar6 72.7W TP 17 ConUS beam (A) (H)
4239 - WGN [MPEG4 HD] moved from EchoStar8 77W TP 13 ConUS beam to Echostar6 72.7W TP 17 ConUS beam (A) (H)
4287 - CI [MPEG4 HD] moved from EchoStar8 77W TP 13 ConUS beam to Echostar6 72.7W TP 17 ConUS beam (A) (H)
5327 - WGN [MPEG4 HD] moved from EchoStar8 77W TP 13 ConUS beam to Echostar6 72.7W TP 17 ConUS beam (A) (H)
5442 - ALT10 [MPEG2 SD] moved from EchoStar7 119W TP 18 ConUS beam to EchoStar11 110W TP 24 ConUS beam (A) (H)
8118 - WNYN [MPEG4 SD] moved from Echostar12 61.5W TP 01 Spotbeam 3 to Echostar12 61.5W TP 07 Spotbeam 3 (A) (H)
9417 - EWTN [MPEG4 SD] moved from Echostar6 72.7W TP 03 ConUS beam to Echostar6 72.7W TP 01 ConUS beam (A) (H)
9446 - WGN [MPEG4 HD] moved from EchoStar8 77W TP 13 ConUS beam to Echostar6 72.7W TP 17 ConUS beam (A)
9457 - GREEN [MPEG4 HD] moved from EchoStar8 77W TP 13 ConUS beam to Echostar6 72.7W TP 17 ConUS beam (A)
9465 - MAVHD [MPEG4 HD] moved from Echostar6 72.7W TP 17 ConUS beam to Echostar6 72.7W TP 27 ConUS beam (A)
9481 - TMC-E [MPEG4 HD] moved from EchoStar8 77W TP 13 ConUS beam to Echostar6 72.7W TP 17 ConUS beam (A)
9495 - CBS C [MPEG4 HD] moved from EchoStar8 77W TP 13 ConUS beam to Echostar6 72.7W TP 17 ConUS beam (A)
9496 - SEDGE [MPEG4 HD] moved from EchoStar8 77W TP 32 ConUS beam to Echostar6 72.7W TP 13 ConUS beam (A) (H)
9498 - STRZW [MPEG4 HD] moved from EchoStar8 77W TP 32 ConUS beam to Echostar6 72.7W TP 13 ConUS beam (A) (H)
9505 - ENCOR [MPEG4 HD] moved from EchoStar8 77W TP 32 ConUS beam to Echostar6 72.7W TP 13 ConUS beam (A) (H)
9531 - DNFYI [MPEG4 HD] moved from Echostar6 72.7W TP 17 ConUS beam to Echostar6 72.7W TP 27 ConUS beam (A)
9620 - BTV [SD TV] moved from EchoStar3 61.5W TP 08 ConUS beam to EchoStar3 61.5W TP 18 ConUS beam (A)
9621 - BTV [SD TV] moved from EchoStar3 61.5W TP 18 ConUS beam to EchoStar3 61.5W TP 10 ConUS beam (A)
9622 - BTV [SD TV] moved from EchoStar3 61.5W TP 18 ConUS beam to EchoStar3 61.5W TP 10 ConUS beam (A)
36610 - ACTVT [161] moved from EchoStar3 61.5W TP 14 ConUS beam to Echostar6 72.7W TP 21 ConUS beam (A)
36701 - MTDTA [EPG] moved from Ciel-2 129W TP 29 ConUS beam to EchoStar7 119W TP 10 ConUS beam (A)
36701 - MTDTA [EPG] moved from EchoStar3 61.5W TP 16 ConUS beam to Echostar6 72.7W TP 03 ConUS beam (A)
36853 - DNL12 [143] moved from EchoStar3 61.5W TP 29 ConUS beam to EchoStar8 77W TP 29 ConUS beam (A)
36854 - DNL10 [143] moved from EchoStar3 61.5W TP 29 ConUS beam to EchoStar8 77W TP 29 ConUS beam (A)
Channel Package Flag Changes:
9640 - WFTV [SD TV] - EchoStar9 121W TP 15 ConUS beam changed to Available(Orlando, FL-ABC)
5659 - KGMB [MPEG4 HD] - EchoStar10 110W TP 23 Spotbeam 47 changed package flags (A)(Honolulu, HI-CBS)
5671 - KFVE [MPEG4 HD] - EchoStar10 110W TP 23 Spotbeam 47 changed package flags (A)(Honolulu, HI-MY)
8901(9) - KGMB [MPEG2 SD] - EchoStar7 119W TP 09 Spotbeam 1 changed package flags (A)(Honolulu, HI-CBS)
8904(5) - KFVE [MPEG2 SD] - EchoStar7 119W TP 09 Spotbeam 1 changed package flags (A)(Honolulu, HI-MY)
5250(9) - KCRG [MPEG4 HD] - Ciel-2 129W TP 03 Spotbeam 21 changed to Available (H)(Cedar Rapids, IA-ABC)
9180(3) - KLEW [MPEG2 SD] - EchoStar10 110W TP 18 Spotbeam 40 changed to Available (H)(Lewiston, ID-CBS)
141 - ESPNU [MPEG2 SD] - EchoStar7 119W TP 04 ConUS beam changed package flags (A)
141 - ESPNU [MPEG4 SD] - Echostar6 72.7W TP 23 ConUS beam changed package flags (A)
165 - MUSIC [MPEG AUDIO] - EchoStar11 110W TP 10 ConUS beam changed package flags (A)
186 - NTGEO [MPEG2 SD] - EchoStar11 110W TP 11 ConUS beam changed package flags (A)
186 - NTGEO [MPEG4 SD] - Echostar6 72.7W TP 01 ConUS beam changed package flags (A)
201 - NOTAX [MPEG2 SD] - EchoStar11 110W TP 02 ConUS beam changed to Not Available
201 - NOTAX [MPEG4 SD] - EchoStar8 77W TP 12 ConUS beam changed to Not Available
203 - BITV [MPEG2 SD] - EchoStar11 110W TP 02 ConUS beam changed package flags (A)
203 - BITV [MPEG4 SD] - Echostar6 72.7W TP 23 ConUS beam changed package flags (A)
233 - NOTAX [MPEG2 SD] - EchoStar11 110W TP 01 ConUS beam changed to Not Available
233 - NOTAX [MPEG4 SD] - EchoStar8 77W TP 12 ConUS beam changed to Not Available
240 - INFO [MPEG2 SD] - EchoStar7 119W TP 15 ConUS beam changed package flags (A)
402 - NBATV [MPEG2 SD] - EchoStar11 110W TP 09 ConUS beam changed package flags (A)
402 - NBATV [MPEG4 SD] - Echostar6 72.7W TP 05 ConUS beam changed package flags (A)
531 - PPV [MPEG2 SD] - EchoStar11 110W TP 10 ConUS beam changed to Available
533 - PPV [MPEG2 SD] - EchoStar7 119W TP 16 ConUS beam changed to Available
597 - RCORD [MPEG2 SD] - EchoStar3 61.5W TP 18 ConUS beam changed to hidden from non-subs (A) (H)
625 - NHLN [MPEG2 SD] - EchoStar11 110W TP 15 ConUS beam changed package flags (A)
625 - NHLN [MPEG4 SD] - Echostar6 72.7W TP 19 ConUS beam changed package flags (A)
627 - NHL [MPEG2 SD] - EchoStar11 110W TP 24 ConUS beam changed package flags (A)
627 - NHL [MPEG4 SD] - Echostar6 72.7W TP 29 ConUS beam changed package flags (A)
629 - NHL [MPEG4 SD] - Echostar6 72.7W TP 19 ConUS beam changed package flags (A)
633 - NHL [MPEG4 SD] - Echostar6 72.7W TP 19 ConUS beam changed package flags (A)
634 - NHL [MPEG4 SD] - Echostar6 72.7W TP 19 ConUS beam changed package flags (A)
637 - NHL [MPEG4 SD] - Echostar6 72.7W TP 19 ConUS beam changed package flags (A)
735 - TRACE [MPEG2 SD] - Anik F3 118.7W TP 03 ConUS beam changed package flags (A)
751 - AFROM [MPEG2 SD] - Anik F3 118.7W TP 02 ConUS beam changed package flags (A)
809 - JUS [MPEG2 SD] - Anik F3 118.7W TP 29 ConUS beam changed to shown in non-sub's guides (A) (H)
815 - RCORD [MPEG2 SD] - Anik F3 118.7W TP 30 ConUS beam changed to hidden from non-subs (A) (H)
919 - MUSIC [MPEG AUDIO] - EchoStar11 110W TP 10 ConUS beam changed package flags (A)
5771 - IAD2 [DATA] - EchoStar11 110W TP 10 ConUS beam changed package flags (A)
5772 - IAD3 [DATA] - EchoStar11 110W TP 10 ConUS beam changed package flags (A)
5773 - IAD4 [DATA] - EchoStar11 110W TP 10 ConUS beam changed package flags (A)
5774 - IAD5 [DATA] - EchoStar11 110W TP 10 ConUS beam changed package flags (A)
9374(2) - KUNW [MPEG2 SD] - EchoStar10 110W TP 12 Spotbeam 45 changed to Available (H)
9508(402) - NBATV [MPEG4 HD] - Ciel-2 129W TP 24 ConUS beam changed package flags (A)
9508(402) - NBATV [MPEG4 HD] - EchoStar3 61.5W TP 22 ConUS beam changed package flags (A)
9541(625) - NHLN [MPEG4 HD] - Ciel-2 129W TP 30 ConUS beam changed package flags (A)
9541(625) - NHLN [MPEG4 HD] - EchoStar3 61.5W TP 02 ConUS beam changed package flags (A)
9543(627) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed package flags (A)
9544(628) - NHLHD [MPEG4 HD] - Ciel-2 129W TP 25 ConUS beam changed package flags (A)
9546(630) - NHLHD [MPEG4 HD] - Ciel-2 129W TP 25 ConUS beam changed package flags (A)
9546(630) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed package flags (A)
9547(631) - NHLHD [MPEG4 HD] - Ciel-2 129W TP 25 ConUS beam changed package flags (A)
9547(631) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 20 ConUS beam changed package flags (A)
9548(632) - NHLHD [MPEG4 HD] - Ciel-2 129W TP 25 ConUS beam changed package flags (A)
9548(632) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed package flags (A)
9549(633) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed package flags (A)
9550(634) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed package flags (A)
9551(635) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 20 ConUS beam changed package flags (A)
9552(636) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed package flags (A)
9553(637) - NHLHD [MPEG4 HD] - Ciel-2 129W TP 25 ConUS beam changed package flags (A)
9553(637) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 20 ConUS beam changed package flags (A)
9554(638) - NHLHD [MPEG4 HD] - Ciel-2 129W TP 25 ConUS beam changed package flags (A)
19029 - BITVV [DATA] - EchoStar11 110W TP 02 ConUS beam changed package flags (A)
Channel Mapdown Changes:
5575 - VH1 Ciel-2 129W TP 12 Spotbeam 1 mapdown of 162 added (A) (H)
Channel Renames:
14007 - KCET1 - EchoStar7 119W TP 03 Spotbeam 5 renamed to KCET2 (NA)
9220(51) - WEVU - EchoStar10 110W TP 04 Spotbeam 01 renamed to WLZE (A) (H)(Fort Myers, FL-N/A)
9220(51) - WEVU - Echostar12 61.5W TP 15 Spotbeam 9 renamed to WLZE (A) (H)(Fort Myers, FL-N/A)
487 - TEEZ - EchoStar11 110W TP 03 ConUS beam renamed to PLBYE (A)
489 - PENT - EchoStar7 119W TP 04 ConUS beam renamed to PLBY (A)
492 - XCESS - EchoStar11 110W TP 03 ConUS beam renamed to REAL (A)
494 - REAL - Echostar6 72.7W TP 21 ConUS beam renamed to JUICY (A)
651 - CLRS - Anik F3 118.7W TP 23 ConUS beam renamed to INTL1 (NA)
651 - CLRS - EchoStar3 61.5W TP 10 ConUS beam renamed to INTL1 (NA)
737 - KINO - Anik F3 118.7W TP 26 ConUS beam renamed to KINOE (A)
5742 - IAD13 - EchoStar11 110W TP 08 ConUS beam renamed to IAD12 (A)
5744 - IAD15 - EchoStar11 110W TP 08 ConUS beam renamed to IAD13 (A)
9345(16) - K20HB - EchoStar10 110W TP 04 Spotbeam 36 renamed to KBGS (A) (H)
9458(310) - MAX - Ciel-2 129W TP 27 ConUS beam renamed to MAX-E (A)
9458(310) - MAX - EchoStar3 61.5W TP 22 ConUS beam renamed to MAX-E (A)
Transponder Changes:
Anik F3 118.7W TP 04 ConUS beam 21500 QPSK TURBO CODED 2/3 removed
Anik F3 118.7W TP 05 ConUS beam 21500 QPSK TURBO CODED 2/3 removed
Anik F3 118.7W TP 08 ConUS beam 21500 QPSK TURBO CODED 2/3 removed
Anik F3 118.7W TP 09 ConUS beam 21500 QPSK TURBO CODED 2/3 removed
Anik F3 118.7W TP 10 ConUS beam 21500 QPSK TURBO CODED 2/3 removed
Anik F3 118.7W TP 12 ConUS beam 21500 QPSK TURBO CODED 2/3 removed
Anik F3 118.7W TP 14 ConUS beam 20000 QPSK 3/4 removed
EchoStar7 119W TP 10 ConUS beam 21500 8PSK 2/3 added
Ciel-2 129W TP 16 Spotbeam 55 changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Echostar12 61.5W TP 17 ConUS beam 20000 QPSK 5/6 added
Echostar6 72.7W TP 01 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Echostar6 72.7W TP 03 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Echostar6 72.7W TP 05 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Echostar6 72.7W TP 07 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Echostar6 72.7W TP 09 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Echostar6 72.7W TP 11 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Echostar6 72.7W TP 13 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Echostar6 72.7W TP 15 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Echostar6 72.7W TP 17 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Echostar6 72.7W TP 19 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Echostar6 72.7W TP 21 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Echostar6 72.7W TP 23 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Echostar6 72.7W TP 25 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Echostar6 72.7W TP 27 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Echostar6 72.7W TP 29 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Echostar6 72.7W TP 31 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
EchoStar8 77W TP 13 ConUS beam changed from 20000 QPSK 5/6 to 22500 QPSK TURBO CODED 5/6
EchoStar8 77W TP 32 ConUS beam changed from 20000 QPSK 5/6 to 22500 QPSK TURBO CODED 5/6
Channels in the system: 6627
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
Audio stutter
CODE FOR VIZIO TV
