Uplink Activity Report - 01/10/2007 - 1 change | SatelliteGuys.US
digiblur
14,190
4
Louisiana
The SatelliteGuys.US Uplink Activity Report - 01/10/2007 - 1 change
Uplink Comparison Range: 01/09/2007 09:53A - 01/10/2007 05:12A - (GMT-06:00) Central Time (US & Canada)
287 - RUSH renamed to AMC (NA)
Channels in the system: 3143
(A) = Available
(NA) = Not Available
Your guess is as good as mine as we all know this channel is used for HD previews. As of this report channel 287 was running around 12mbps, and we also all know E* SD doesn't run at 12mbps.
Thanks to JohnH on the heads up on this change. There might be more changes later. If Scott doesn't post them I won't be able to until later this evening.
For E* to put AMC into that slot it only makes sense that its a new HD channel. AMCHD? I hope its true. We need more HD channels.
I do believe AMC-HD was SUPPOSED to launch on Voom before it folded. Can any of the old voomers confirm or deny this?
Either way this is good news. If it's a new HD channel that would be awesome. If it's the SD AMC then maybe they'll (re)up the resoluiton and bitrate on the HDNet channels.
Wait, why am I being so positive???
full court?
HD from Dish. What do you want ?
