Uplink Activity Report - 11/30/2006 | SatelliteGuys.US
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
103,710
29,462
Newington, CT
The SatelliteGuys.US Uplink Activity Report - 11/30/2006 - 30 changes
Uplink Comparison Range: 11/29/2006 02:39P - 11/30/2006 08:39A - (GMT-05:00) Eastern Time (US & Canada)
132 - TCM moved from EchoStar7 119W TP 15 ConUS beam to EchoStar7 119W TP 13 ConUS beam (A)
171 - NICKW moved from EchoStar7 119W TP 15 ConUS beam to EchoStar7 119W TP 16 ConUS beam (A)
232 - KTLA moved from EchoStar7 119W TP 15 ConUS beam to EchoStar7 119W TP 20 ConUS beam (A)
252 - KTLA moved from EchoStar7 119W TP 15 ConUS beam to EchoStar7 119W TP 20 ConUS beam (A)
262 - ANGEL moved from EchoStar7 119W TP 15 ConUS beam to EchoStar7 119W TP 21 ConUS beam (A)
299 - REELZ moved from EchoStar7 119W TP 15 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
511 - PPV moved from EchoStar7 119W TP 21 ConUS beam to EchoStar8 110W TP 16 ConUS beam (A)
514 - PPV moved from EchoStar8 110W TP 16 ConUS beam to EchoStar8 110W TP 06 ConUS beam (A)
519 - PPV moved from EchoStar7 119W TP 12 ConUS beam to EchoStar8 110W TP 10 ConUS beam (A)
537 - HERE removed from EchoStar8 110W TP 10 ConUS beam
539 - ESPPV removed from EchoStar8 110W TP 06 ConUS beam
692 - VLAND renamed to SLNK2 (A)
861 - ESPPV removed from EchoStar8 110W TP 06 ConUS beam
5731 - TST1A added to EchoStar7 119W TP 15 ConUS beam (Available)
5732 - TST2A added to EchoStar7 119W TP 15 ConUS beam (Available)
5733 - TST1B added to EchoStar7 119W TP 15 ConUS beam (Available)
5734 - TST2B added to EchoStar7 119W TP 15 ConUS beam (Available)
5735 - TST1C added to EchoStar7 119W TP 15 ConUS beam (Available)
5736 - TST2C added to EchoStar7 119W TP 15 ConUS beam (Available)
5737 - TST1D added to EchoStar7 119W TP 15 ConUS beam (Available)
5738 - TST2D added to EchoStar7 119W TP 15 ConUS beam (Available)
5822 - VOD moved from EchoStar8 110W TP 16 ConUS beam to EchoStar8 110W TP 06 ConUS beam (NA)
5990 - CPTST removed from EchoStar7 119W TP 15 ConUS beam
8004 - KTLA moved from EchoStar7 119W TP 15 ConUS beam to EchoStar7 119W TP 20 ConUS beam (A)
9411 - NAUHS moved from EchoStar7 119W TP 20 ConUS beam to EchoStar7 119W TP 12 ConUS beam (A)
9931 - VOD moved from EchoStar8 110W TP 16 ConUS beam to EchoStar8 110W TP 06 ConUS beam (NA)
14535 - KWGN2 moved from EchoStar7 119W TP 15 ConUS beam to EchoStar7 119W TP 20 ConUS beam (NA)
14753 - KNBC2 moved from EchoStar7 119W TP 15 ConUS beam to EchoStar7 119W TP 20 ConUS beam (NA)
32768 - WBSTR moved from EchoStar7 119W TP 15 ConUS beam to EchoStar7 119W TP 19 ConUS beam (NA)
Channels in the system: 3182
(A) = Available
(NA) = Not Available
The 57xx's now have names.....
The SatelliteGuys.US Uplink Activity Report - 11/30/2006 - 8 changes
Uplink Comparison Range: 11/29/2006 08:30A - 11/30/2006 06:51P - (GMT-06:00) Central Time (US & Canada)
5731 - WXIA added to EchoStar7 119W TP 15 ConUS beam (Available)
5732 - KNTV added to EchoStar7 119W TP 15 ConUS beam (Available)
5733 - WGCL added to EchoStar7 119W TP 15 ConUS beam (Available)
5734 - KPIX added to EchoStar7 119W TP 15 ConUS beam (Available)
5735 - WSB added to EchoStar7 119W TP 15 ConUS beam (Available)
5736 - KGO added to EchoStar7 119W TP 15 ConUS beam (Available)
5737 - WAGA added to EchoStar7 119W TP 15 ConUS beam (Available)
5738 - KTVU added to EchoStar7 119W TP 15 ConUS beam (Available)
(A) = Available
This might be early... more changes might come.
The SatelliteGuys.US Uplink Activity Report - 11/30/2006 - 36 changes
Uplink Comparison Range: 11/30/2006 06:51P - 11/30/2006 11:06P - (GMT-06:00) Central Time (US & Canada)
103 - ONPPV removed from EchoStar7 119W TP 16 ConUS beam
210 - CSPAN moved from EchoStar7 119W TP 11 ConUS beam to EchoStar7 119W TP 17 ConUS beam (A)
212 - CSPN2 moved from EchoStar7 119W TP 11 ConUS beam to EchoStar7 119W TP 08 ConUS beam (A)
222 - HSN moved from EchoStar7 119W TP 11 ConUS beam to EchoStar7 119W TP 16 ConUS beam (A)
226 - QVC moved from EchoStar7 119W TP 11 ConUS beam to EchoStar7 119W TP 16 ConUS beam (A)
228 - SHNBC moved from EchoStar7 119W TP 11 ConUS beam to EchoStar7 119W TP 16 ConUS beam (A)
299 - REELZ moved from EchoStar7 119W TP 11 ConUS beam to EchoStar7 119W TP 04 ConUS beam (A)
500 - ONPPV removed from EchoStar7 119W TP 16 ConUS beam
505 - PPV removed from EchoStar7 119W TP 16 ConUS beam
509 - PPV removed from EchoStar7 119W TP 17 ConUS beam
6200 - WJLA removed from EchoStar10 110W TP 25 Spotbeam 05 from Mount Jackson
6201 - WUSA removed from EchoStar10 110W TP 25 Spotbeam 05 from Mount Jackson
6202 - WRC removed from EchoStar10 110W TP 25 Spotbeam 05 from Mount Jackson
6203 - KTBS removed from EchoStar10 110W TP 27 Spotbeam 15 from New Braunfels
6204 - KMSS removed from EchoStar10 110W TP 27 Spotbeam 15 from New Braunfels
6205 - KSAT removed from EchoStar10 110W TP 23 Spotbeam 22 from New Braunfels
6206 - KENS removed from EchoStar10 110W TP 23 Spotbeam 22 from New Braunfels
6208 - WRTV removed from EchoStar10 110W TP 18 Spotbeam 13 from Monee
6209 - WTHR removed from EchoStar10 110W TP 18 Spotbeam 13 from Monee
6211 - WCTV removed from EchoStar10 110W TP 25 Spotbeam 03 from Mount Jackson
6217 - WAPT removed from EchoStar10 110W TP 26 Spotbeam 11 from New Braunfels
6218 - WJTV removed from EchoStar10 110W TP 26 Spotbeam 11 from New Braunfels
6219 - WLBT removed from EchoStar10 110W TP 26 Spotbeam 11 from New Braunfels
6220 - WUFX removed from EchoStar10 110W TP 26 Spotbeam 11 from New Braunfels
6221 - WDBD removed from EchoStar10 110W TP 26 Spotbeam 11 from New Braunfels
6226 - WDBJ removed from EchoStar10 110W TP 25 Spotbeam 05 from Mount Jackson
6227 - WSLS removed from EchoStar10 110W TP 25 Spotbeam 05 from Mount Jackson
6233 - WMUR removed from EchoStar10 110W TP 26 Spotbeam 04 from Mount Jackson
6234 - WMUR removed from EchoStar10 110W TP 26 Spotbeam 04 from Mount Jackson
6235 - WFMY removed from EchoStar10 110W TP 31 Spotbeam 05 from Mount Jackson
6236 - WXII removed from EchoStar10 110W TP 31 Spotbeam 05 from Mount Jackson
7658 - KRIV removed from EchoStar10 110W TP 29 Spotbeam 17 from New Braunfels
7926 - WTVY removed from EchoStar10 110W TP 04 Spotbeam 07 from New Braunfels
19046 - ESFFL removed from EchoStar7 119W TP 04 ConUS beam
19064 - FFTV removed from EchoStar7 119W TP 04 ConUS beam
19067 - ESPNI removed from EchoStar7 119W TP 04 ConUS beam
Channels in the system: 3152
(A) = Available
Dang it. This is ridiculous. I wonder if it's possible for NPS to provide significantly viewed channels.
I think they'd have to set it up so NPS "independently" provided the locals to the affected markets. It's one thing to lease a conus transponder, but I'm not sure leasing individual spotbeams would pass the smell test.
Uplink Comparison Range: 11/30/2006 11:06P - 11/30/2006 11:31P - (GMT-06:00) Central Time (US & Canada)
242 - NBC-W moved from EchoStar7 119W TP 15 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
244 - CBS-W moved from EchoStar7 119W TP 15 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
246 - ABC-W moved from EchoStar7 119W TP 15 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
248 - FOX-W moved from EchoStar7 119W TP 15 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
8000 - KABC moved from EchoStar7 119W TP 15 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
8001 - KCBS moved from EchoStar7 119W TP 15 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
8002 - KNBC moved from EchoStar7 119W TP 15 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
8003 - KTTV moved from EchoStar7 119W TP 15 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
(A) = Available
You're right. I didn't think about that. Probably not feasible.
Special Charlie Chat Tonight!
ViP 211, OTA, HD locals
