Uplink Activity Report - 7/31/2008 12:02pm - 20 changes | SatelliteGuys.US
D
DigiSAT Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 7/31/2008 12:02pm - 20 changes
Uplink Comparison Range: 07/31/2008 11:01A - 07/31/2008 12:02P
Channel Additions:
6799(75) - HIDEF [MPEG2 SD ViP] added to EchoStar8 110W TP 19 ConUS beam (NA)
Channel Removals:
75 - HIDEF (A) (H) removed from EchoStar8 110W TP 19 ConUS beam
Channel Moves:
9622 - BTV [SD TV] moved from Echostar12 61.5W TP 23 ConUS beam to EchoStar3 61.5W TP 18 ConUS beam (A)
Channel Package Flag Changes:
8105(9) - WWOR [MPEG4 SD] - Echostar12 61.5W TP 15 Area 6 beam changed to Available (H)(Secaucus, NJ)
8106(13) - WNET [MPEG4 SD] - Echostar12 61.5W TP 15 Area 6 beam changed to Available (H)(Newark, NJ)
8107(55) - WLNY [MPEG4 SD] - Echostar12 61.5W TP 15 Area 6 beam changed to Available (H)(Riverhead, NY)
8108(41) - WXTV [MPEG4 SD] - Echostar12 61.5W TP 15 Area 6 beam changed to Available (H)(Paterson, NJ)
8109(47) - WNJU [MPEG4 SD] - Echostar12 61.5W TP 15 Area 6 beam changed to Available (H)(Linden, NJ)
8110(67) - WFTY [MPEG4 SD] - Echostar12 61.5W TP 15 Area 6 beam changed to Available (H)(Smithtown, NY)
8112(21) - WLIW [MPEG4 SD] - Echostar12 61.5W TP 01 Area 6 beam changed to Available (H)(Garden City, NY)
8113(58) - WNJB [MPEG4 SD] - Echostar12 61.5W TP 07 Area 6 beam changed to Available (H)(New Brunswick, NJ)
8114(25) - WNYE [MPEG4 SD] - Echostar12 61.5W TP 07 Area 6 beam changed to Available (H)(New York, NY)
8115(63) - WMBC [MPEG4 SD] - Echostar12 61.5W TP 01 Area 6 beam changed to Available (H)(Newton, NJ)
8116(62) - WRNN [MPEG4 SD] - Echostar12 61.5W TP 01 Area 6 beam changed to Available (H)(Kingston, NY)
8117(66) - WFME [MPEG4 SD] - Echostar12 61.5W TP 01 Area 6 beam changed to Available (H)(West Milford, NJ)
8118(39) - WNYN [MPEG4 SD] - Echostar12 61.5W TP 01 Area 6 beam changed to Available (H)
Channel Type Changes:
7526(60) - PBS Echostar12 61.5W TP 23 ConUS beam changed from MPEG2 SD ViP to MPEG4 SD (NA)
7866(60) - PBS Echostar12 61.5W TP 23 ConUS beam changed from MPEG2 SD ViP to MPEG4 SD (NA)
8175(60) - PBS Echostar12 61.5W TP 23 ConUS beam changed from MPEG2 SD ViP to MPEG4 SD (NA)
8448(60) - PBS Echostar12 61.5W TP 23 ConUS beam changed from MPEG2 SD ViP to MPEG4 SD (NA)
Channels in the system: 5064
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
I believe that Scott said to expect them overnight for the 8/1 turn-on date.
I got an e-mail this morning stating "Effective August 1, 2008 by 5 pm ET, DISH Network will have launched the following MPEG-4 HD Channels!" It then went on to list out channels and packages for the 17 coming tomorrow...
I live in NJ and can see all of these channels. What's the purpose of them? They have no mapdowns to the regular channel numbers.
Yes they do. Your receiver will just choose the ones it cares to see. :) If you have 61.5° and 110°/119° and an MPEG4 receiver, the receiver will automatically select whatever channel it wants.
Eventually, all new NYC customers will be looking at 61.5°, 72.7° and 77° with an Eastern Arc Dish.
See ya
Tony
THERE= a place. not here - THEIR= belongs to them - THEY'RE = short for "They Are". example: They're over there with their friends.
THEN = a point in time; not now. - THAN = used to compare things. example "Better then than now."
-Something AFFECTS you. You have an EFFECT on something
You forgot the biggest one:
LOOSE = when something is not tied down - LOSE = when you never get that new job because you cannot spell
I've been fighting that battle for years. What's weird is I've only ever seen it on Satellite boards.
D
Uplink Activity Report - 7/23/2008 12:17pm - 130 changes
D
Uplink Activity Report - 8/8/2008 1:02pm - 4 changes
