Uplink Activity Report - 8/13/2008 1:48pm - 47 changes | SatelliteGuys.US
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
103,427
28,490
Newington, CT
SatelliteGuys.US DishNetwork Uplink Activity Report - 8/13/2008 1:48pm - 47 changes
Uplink Comparison Range: 08/13/2008 01:30P - 08/13/2008 01:48P
Channel Additions:
211 - DNC08 [MPEG2 SD] added to EchoStar8 110W TP 10 ConUS beam (NA)
211 - DNC08 [MPEG4 SD] added to Echostar6 72.7W TP 27 ConUS beam (NA)
5154(32) - WMOR [MPEG4 HD] added to Echostar12 61.5W TP 07 Area 2 beam (NA)(Lakeland, FL)
5973 - VIDE1 [MPEG2 SD] added to EchoStar1 148W TP 17 ConUS beam (NA)
5998 - INFO4 [MPEG2 SD] added to EchoStar8 110W TP 21 ConUS beam (NA)
5999 - INFO5 [MPEG2 SD] added to EchoStar8 110W TP 21 ConUS beam (NA)
6156 - ISMOV [MPEG2 SD] added to EchoStar3 61.5W TP 14 ConUS beam (A) (H)
6157 - TRACE [MPEG2 SD] added to EchoStar3 61.5W TP 12 ConUS beam (A) (H)
6201 - TNT [MPEG2 HD] added to EchoStar8 110W TP 07 ConUS beam (A) (H)
6202 - HDNMV [MPEG2 HD] added to EchoStar8 110W TP 07 ConUS beam (A) (H)
9636 - INSP [MPEG2 SD] added to EchoStar8 110W TP 02 ConUS beam (NA)
15049 - KHCV5 [EPG] added to EchoStar7 119W TP 03 Northwest beam (NA)(Seattle, WA)
Channel Removals:
211 - NOTAX (NA) removed from EchoStar8 110W TP 02 ConUS beam
712 - MABHY (A) removed from Anik F3 118.7W TP 02 ConUS beam
5997 - INFO3 (NA) removed from EchoStar8 110W TP 02 ConUS beam
Channel Moves:
137 - QVC [MPEG4 SD] moved from Echostar6 72.7W TP 25 ConUS beam to Echostar6 72.7W TP 27 ConUS beam (NA)
590 - TRACE [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to EchoStar3 61.5W TP 14 ConUS beam (A) (H)
974 - CD 25 [MPEG AUDIO] moved from Echostar6 72.7W TP 27 ConUS beam to Echostar6 72.7W TP 25 ConUS beam (NA)
975 - CD 26 [MPEG AUDIO] moved from Echostar6 72.7W TP 27 ConUS beam to Echostar6 72.7W TP 25 ConUS beam (NA)
976 - CD 27 [MPEG AUDIO] moved from Echostar6 72.7W TP 27 ConUS beam to Echostar6 72.7W TP 25 ConUS beam (NA)
977 - CD 28 [MPEG AUDIO] moved from Echostar6 72.7W TP 27 ConUS beam to Echostar6 72.7W TP 25 ConUS beam (NA)
978 - CD 29 [MPEG AUDIO] moved from Echostar6 72.7W TP 27 ConUS beam to Echostar6 72.7W TP 25 ConUS beam (NA)
979 - CD 30 [MPEG AUDIO] moved from Echostar6 72.7W TP 27 ConUS beam to Echostar6 72.7W TP 25 ConUS beam (NA)
981 - CD 32 [MPEG AUDIO] moved from Echostar6 72.7W TP 27 ConUS beam to Echostar6 72.7W TP 25 ConUS beam (NA)
983 - KDMSC [MPEG AUDIO] moved from Echostar6 72.7W TP 27 ConUS beam to Echostar6 72.7W TP 25 ConUS beam (NA)
7601 - WHBF [MPEG2 SD] moved from EchoStar8 110W TP 14 ConUS beam to EchoStar8 110W TP 21 ConUS beam (A) (H)(Rock Island, IL)
9110 - WOI [MPEG2 SD] moved from EchoStar8 110W TP 02 ConUS beam to EchoStar8 110W TP 21 ConUS beam (A) (H)(Ames, IA)
Channel Package Flag Changes:
619 - B4U [MPEG2 SD] - EchoStar1 148W TP 01 ConUS beam changed package flags (A)
619 - B4U [MPEG2 SD] - EchoStar3 61.5W TP 27 ConUS beam changed package flags (A)
660 - RFI [MPEG AUDIO] - EchoStar1 148W TP 01 ConUS beam changed package flags (A)
660 - RFI [MPEG AUDIO] - EchoStar3 61.5W TP 27 ConUS beam changed package flags (A)
732 - RFI [MPEG AUDIO] - Anik F3 118.7W TP 03 ConUS beam changed package flags (A)
773 - IQRAA [MPEG2 SD] - Anik F3 118.7W TP 22 ConUS beam changed package flags (A)
782 - IQRAA [MPEG2 SD] - EchoStar1 148W TP 09 ConUS beam changed package flags (A)
782 - IQRAA [MPEG2 SD] - EchoStar3 61.5W TP 08 ConUS beam changed package flags (A)
791 - B4U [MPEG2 SD] - Anik F3 118.7W TP 22 ConUS beam changed package flags (A)
914 - NT105 [MPEG AUDIO] - Anik F3 118.7W TP 30 ConUS beam changed package flags (A)
914 - NT105 [MPEG AUDIO] - EchoStar3 61.5W TP 14 ConUS beam changed package flags (A)
915 - ERA-5 [MPEG AUDIO] - Anik F3 118.7W TP 30 ConUS beam changed package flags (A)
915 - ERA-5 [MPEG AUDIO] - EchoStar1 148W TP 07 ConUS beam changed package flags (A)
915 - ERA-5 [MPEG AUDIO] - EchoStar3 61.5W TP 14 ConUS beam changed package flags (A)
916 - ERASP [MPEG AUDIO] - Anik F3 118.7W TP 26 ConUS beam changed package flags (A)
916 - ERASP [MPEG AUDIO] - EchoStar1 148W TP 11 ConUS beam changed package flags (A)
916 - ERASP [MPEG AUDIO] - EchoStar3 61.5W TP 18 ConUS beam changed package flags (A)
9369(37) - KRCW [MPEG2 SD] - EchoStar10 110W TP 27 Spotbeam 44 changed to Available (H)(Salem, OR)
Channel Type Changes:
5747 - STVOD EchoStar8 110W TP 14 ConUS beam changed from 134 to DATA (A) (H)
Channel Renames:
7882(29) - WDCO - EchoStar7 119W TP 07 Carolinas beam renamed to WMUM (A) (H)
Channels in the system: 5520
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
9636 says INSP
isnt that some type of religous channel like Inspirational Network
i know that i have family who had comcast and they had that channel and switched
to dish network and lost that channel.. if it is INSP the inspirational network i know they will be happy
In SD for Dish viewers. I guess 2 channels for MPEG2 HD receivers in 6200 range.
Dish is running 2 special HD Olympics channels that will be no longer be needed a few hours before the Dem Convention starts.
So, it seems probably that the HD feed will start around the end of the Olympics, and will likely be mapped to the same 211 channel number.
Both the 6200 channels are visible in my Guide, and I have vanilla AT250 + Dish-HD Ultimate.
Maybe they are moving the 9000 numbers to 6200 ?
i live in oregon and
noticed in the uplink report:
but it is not viewable for me also the mapdown of that channel is actually 32
also i am curious where this came from i can see WSBK now on channel 38 now i have the SUPERSTATIONS package this is new never seen this mapdown before
Or (wishful thinking) is this the first step in converting the MPEG2 9000 HD channels into MPEG4...
They don't need to change the channel number to do that.
They changed the Voom MPEG2-HD channels to MPEG4-HD without changing the numbers.
Actually changing the channel numbers is a bigger change than changing from MPEG2-HD to MPEG4-HD - because all timers would fail because the channel would no longer exist at that number.
I'm pretty sure that the MPEG2-HD to MPEG4-HD change will be finished by September 1st. Probably the reason that it is not yet done is either because a few customers were not yet switched by installers, or more likely, that they are simply waiting for EchoStar 11 to arrive and will put the MPEG4-HD versions straight onto E*11.
Ah, that makes sense. Still learing how to read the uplink tea leaves ;)
