Uplink Activity Report - 8/20/2008 1:48pm - 48 changes | SatelliteGuys.US
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
103,696
29,420
Newington, CT
SatelliteGuys.US DishNetwork Uplink Activity Report - 8/20/2008 1:48pm - 48 changes
Uplink Comparison Range: 08/20/2008 01:38P - 08/20/2008 01:48P
Channel Additions:
259 - INSP [MPEG2 SD] added to EchoStar8 110W TP 08 ConUS beam (NA)
5756 - ATOOL [134] added to Echostar6 72.7W TP 21 ConUS beam (A) (H)
6158 - GLBL1 [MPEG2 SD] added to EchoStar3 61.5W TP 08 ConUS beam (A) (H)
6159 - TELSD [MPEG2 SD] added to EchoStar3 61.5W TP 12 ConUS beam (A) (H)
6203 - ESPN [MPEG2 HD] added to EchoStar8 110W TP 07 ConUS beam (A) (H)
6204 - HDNET [MPEG2 HD] added to EchoStar8 110W TP 07 ConUS beam (A) (H)
6205 - HBO-E [MPEG2 HD] added to EchoStar8 110W TP 13 ConUS beam (A) (H)
6206 - HDTHR [MPEG2 HD] added to EchoStar8 110W TP 13 ConUS beam (A) (H)
6207 - SHO-E [MPEG2 HD] added to EchoStar8 110W TP 13 ConUS beam (A) (H)
7910(52) - WBOYD [MPEG2 SD] added to EchoStar5 129W TP 32 ConUS beam (NA)(Clarksburg, WV)
19211 - MTV [DATA] added to EchoStar7 119W TP 06 ConUS beam (A) (H)
Channel Removals:
9636 - INSP (NA) removed from EchoStar8 110W TP 02 ConUS beam
19055 - ZP2IT (A) removed from EchoStar8 110W TP 06 ConUS beam
Channel Moves:
591 - TELSD [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to EchoStar3 61.5W TP 14 ConUS beam (A) (H)
702 - GLBL1 [MPEG2 SD] moved from EchoStar3 61.5W TP 08 ConUS beam to EchoStar3 61.5W TP 14 ConUS beam (A) (H)
944 - AUD17 [MPEG AUDIO] moved from EchoStar7 119W TP 06 ConUS beam to EchoStar7 119W TP 16 ConUS beam (A) (H)
Channel Package Flag Changes:
211 - DNC08 [MPEG2 SD] - EchoStar8 110W TP 10 ConUS beam changed to Available
Channel Type Changes:
9422(362) - HDNET EchoStar8 110W TP 07 ConUS beam changed from MPEG2 HD to MPEG2 HD ViP (A)
9456(300) - HBO EchoStar8 110W TP 13 ConUS beam changed from MPEG2 HD to MPEG2 HD ViP (A)
Channel Renames:
135 - BBC - Echostar6 72.7W TP 05 ConUS beam renamed to BBCA (NA)
135 - BBC - EchoStar7 119W TP 12 ConUS beam renamed to BBCA (A)
184 - ANIML - Echostar6 72.7W TP 31 ConUS beam renamed to APL (NA)
184 - ANIML - EchoStar7 119W TP 02 ConUS beam renamed to APL (A)
193 - SCIEN - Echostar6 72.7W TP 01 ConUS beam renamed to SCI (NA)
193 - SCIEN - EchoStar8 110W TP 11 ConUS beam renamed to SCI (A)
195 - MLTRY - Echostar6 72.7W TP 15 ConUS beam renamed to MIL (NA)
195 - MLTRY - EchoStar8 110W TP 05 ConUS beam renamed to MIL (A)
215 - TRAV - Echostar6 72.7W TP 11 ConUS beam renamed to TRV (NA)
215 - TRAV - EchoStar7 119W TP 06 ConUS beam renamed to TRV (A)
845 - DISCE - EchoStar8 110W TP 09 ConUS beam renamed to DSCE (A)
879 - BBC - EchoStar7 119W TP 12 ConUS beam renamed to BBCA (A)
887 - ANIML - EchoStar7 119W TP 02 ConUS beam renamed to APL (A)
4184(184) - ANIML - Echostar12 61.5W TP 19 ConUS beam renamed to APL (A) (H)
4184(184) - ANIML - EchoStar5 129W TP 19 ConUS beam renamed to APL (A) (H)
4193(193) - SCIEN - Echostar12 61.5W TP 19 ConUS beam renamed to SCI (A) (H)
4193(193) - SCIEN - EchoStar5 129W TP 19 ConUS beam renamed to SCI (A) (H)
4215(215) - TRAV - EchoStar3 61.5W TP 32 ConUS beam renamed to TRV (A) (H)
4215(215) - TRAV - EchoStar5 129W TP 07 ConUS beam renamed to TRV (A) (H)
5332 - ANIML - Echostar12 61.5W TP 19 ConUS beam renamed to APL (A) (H)
5332 - ANIML - EchoStar5 129W TP 19 ConUS beam renamed to APL (A) (H)
5366 - TRAV - EchoStar3 61.5W TP 32 ConUS beam renamed to TRV (A) (H)
5366 - TRAV - EchoStar5 129W TP 07 ConUS beam renamed to TRV (A) (H)
9437(215) - TRAV - EchoStar3 61.5W TP 32 ConUS beam renamed to TRV (A)
9437(215) - TRAV - EchoStar5 129W TP 07 ConUS beam renamed to TRV (A)
9489(184) - ANIML - Echostar12 61.5W TP 19 ConUS beam renamed to APL (A)
9489(184) - ANIML - EchoStar5 129W TP 19 ConUS beam renamed to APL (A)
9490(193) - SCIEN - Echostar12 61.5W TP 19 ConUS beam renamed to SCI (A)
9490(193) - SCIEN - EchoStar5 129W TP 19 ConUS beam renamed to SCI (A)
Channels in the system: 5530
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
I dont think this is all, I expected all the channels at 72.7 to become available today for the launch of Eastern Arc service...
We will keep checking. :)
They are alerting people with MPEG2 equpment that the MPEG2 HD channels will soon be converting to MPEG4 and that they need to upgrade now to avoid losing their HD programming.
The 6200 will be for those with MPEG2 HD receivers. Our friend Tony explained it best, but it is where all MPEG2 HD channels will be together before the migration. The customer with old HD receiver will have to call about upgrading their service because their HD channels will be turning off soon. Those with MPEG4 HD receiver are receiving both feeds.
Scott: You are faster at typing :)
Yep, basically you'll be missing the channels now on your MPEG2 equipment. So you call in and ask what's going on? They tell you about upgrading equipment then tell you in the meantime to tune to the 6200's until your equipment upgrade is completed.
Awesome thanks guys for all the advice!! :) I'm wondering if all the uplinked material yesterday is going live like Scott said...probably not through with todays uplinks :)
My thought exactly. I wonder in any Eastern Arc intstalls were atempted this morning, only to find zero SD channels available.
And I don't get the Discover Channels renames, adding ambiguity:confused: (Although the BBC one was good, as it isn't the full BBC.)
The Discovery channel family of channels renames are to conform with the channels listings and ads around the country. Our paper has been using those abbreviations since the channels came on the air!
See ya
Tony
D
Uplink Activity Report - 8/15/2008 12:02pm - 4 changes
D
Uplink Activity Report - 8/20/2008 1:07pm - 48 changes
