Uplink Activity Report - 8/25/2008 6:02am - 1 change | SatelliteGuys.US
D
DigiSAT Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 8/25/2008 6:02am - 1 change
Uplink Comparison Range: 08/25/2008 05:02A - 08/25/2008 06:02A
Channel Moves:
5414 - FOXRM [MPEG4 HD] moved from EchoStar3 61.5W TP 20 ConUS beam to EchoStar3 61.5W TP 30 ConUS beam (A) (H)
Channels in the system: 5533
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
Doesn't say in that thread that 211 is going HD...
True. I suppose it doesn't say we will get to see the convention in HD, just that it will be HD in the convention. I assumed too much. That will suck if we are stuck with it in SD.
Ted
Plenty of other sources (well CNN and CNBC on dish maybe, plus your local networks hd coverage of it if you get those)
Politics aside... In order to watch the HD feed of channel 211/9445 you'll need a dish pointing to 61.5 trans 16. The 211 SD channel broadcast is on satellite 110 trans 10.
D
Uplink Activity Report - 8/25/2008 6:02pm - 2 changes
D
Uplink Activity Report - 8/26/2008 1:34pm - 1 change
