Uplink Report - Aug 29th 2006 | SatelliteGuys.US
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
103,711
29,479
Newington, CT
The SatelliteGuys.US Uplink Activity Report - 08/29/2006 - 30 changes
Uplink Comparison Range: 08/28/2006 02:52P - 08/29/2006 07:26A
102 - TVGC moved from 119.0W TP 16 to 110.0W TP 2
110 - FOOD moved from 119.0W TP 4 to 119.0W TP 6
116 - GAME moved from 119.0W TP 4 to 119.0W TP 8
140 - ESPN moved from 119.0W TP 8 to 119.0W TP 4
143 - ESPCL moved from 119.0W TP 6 to 119.0W TP 4
148 - ESPNU moved from 110.0W TP 5 to 119.0W TP 4
154 - NFL moved from 110.0W TP 21 to 119.0W TP 16
161 - MTV2 moved from 119.0W TP 4 to 119.0W TP 2
265 - CCTV9 moved from 119.0W TP 16 to 110.0W TP 22
333 - FLIX moved from 119.0W TP 4 to 119.0W TP 19
884 - CCEF moved from 119.0W TP 16 to 110.0W TP 22
980 - CD 31 moved from 119.0W TP 4 to 119.0W TP 19
6399 - KQCA moved from 129.0W TP 7 to 110.0W TP 18
6444 - TEST removed from 129.0W TP 7
9470 - RAVE moved from 129.0W TP 30 to 129.0W TP 31
9470 - RAVE moved from 61.5W TP 3 to 61.5W TP 13
9474 - ANIMA moved from 129.0W TP 23 to 129.0W TP 31
9474 - ANIMA moved from 61.5W TP 7 to 61.5W TP 13
9478 - ULTRA moved from 129.0W TP 31 to 129.0W TP 6
9478 - ULTRA moved from 61.5W TP 13 to 61.5W TP 1
9480 - FILMF moved from 129.0W TP 6 to 129.0W TP 31
9480 - FILMF moved from 61.5W TP 1 to 61.5W TP 13
9485 - GAMEP moved from 129.0W TP 31 to 129.0W TP 30
9485 - GAMEP moved from 61.5W TP 13 to 61.5W TP 3
9486 - FAMLY moved from 129.0W TP 31 to 129.0W TP 23
9486 - FAMLY moved from 61.5W TP 13 to 61.5W TP 7
9892 - INTH3 removed from 110.0W TP 18
14608 - ATLK1 moved from 110.0W TP 16 to 119.0W TP 18
14609 - ATLK2 moved from 110.0W TP 16 to 119.0W TP 18
19012 - TVGUI moved from 119.0W TP 16 to 110.0W TP 2
Channels in the system: 2950
I actually knew most of the moves they were going to make last night. :)
Next week there is a lot of shuffling going on at 129.
What kind of shuffeling at 129 I'm getting a dish 1000 installed Sunday and will be losing my 61.5 :(
thanks for the info
Scott you forgot a new local being added
7500 KNWA-TV NBC Rogers, Arkansas became available. Ft. Smith Market NBC
The NBC that was uplinked is switching to Fox and KPBI (current Fox) is going "My network"
Sometimes when they move channels from one transponder to another like this, service calls increase if the customer is having an issue with the particular transponder on the lnbf that the channel is getting moved to.
Let's take action and let the FTC.....
Cheap HDMI cables???
