USAHD quality | SatelliteGuys.US
USAHD quality
goaliebob99
14,487
521
Is it just me or does USAHD seem a little bit extra Microblocky than normal. Normally during WWE raw, you get Microblocks due to the fast motion, but tonight the quality just seems down right worse than normal. Anyone else noticing this? Also, if Directv could set the encoding profile during raw and the fast motion, that would be the best time to do so as if the encoder can handle raw with out high microblocking, then it can handle just about any other program out there. I would suggest doing it during Rey Mistero's entrance (high fireworks) Wich sucks out the bitrate of the transpoder.
Order DNS online after "move"???
Samsung SIR-TS360 not displaying HD
