charlesrshell SatelliteGuys Crazy Original poster Lifetime Supporter Jan 14, 2006 11,236 5,973 O'Fallon, IL Dec 26, 2010 #1 Is there a problem using a USB hub with a 722k? Should it be a power hub? Want to connect a Sling Adapter and EHD but don't want to use the USB port in the front.
Dah-Henny SatelliteGuys Pro May 12, 2007 3,666 346 Boone, North Carolina Dec 26, 2010 #2 Definitely use a powered hub.
charlesrshell SatelliteGuys Crazy Original poster Lifetime Supporter Jan 14, 2006 11,236 5,973 O'Fallon, IL Dec 26, 2010 #3 OK, thanks dahenny.
Joe Satellite Fan SatelliteGuys Pro Dec 7, 2010 244 11 Palisade, Colorado Dec 27, 2010 #4 Yep, that's the fix. I got a Rosewill RHUB-310R from NewEgg for $12.99 and it did the trick for me.
