F FryMan New Member Original poster Jan 31, 2007 2 0 Jul 6, 2007 #1 Does the USB ports allow for any functionality on the HD DVR? Is there any way to download/copy recorded TV shows to free up space on the DVR?
B bonscott87 SatelliteGuys Pro Aug 27, 2004 925 1 Jul 6, 2007 #2 They are not active. You can connect the H20 to any DVD recorder or PC capture card you wish via the various A/V connections (component, RCA, etc).
Bob Nielsen SatelliteGuys Pro Aug 22, 2006 1,721 0 Bainbridge Island, WA Jul 7, 2007 #3 Some folks use the USB port to power a fan (the H20-600 runs pretty hot).
Brewer4 SatelliteGuys Pro Supporting Founder Mar 12, 2005 4,022 0 Hartford Connecticut Jul 7, 2007 #4 Bob Nielsen said: Some folks use the USB port to power a fan (the H20-600 runs pretty hot). Click to expand... I know. I have my 4 units stacked and I had to put a separator and isolate the H20 to the way top. You can cook an egg on it.
vurbano On Double Secret Probation Supporting Founder Apr 1, 2004 23,815 104 Newport News, VA Jul 7, 2007 #5 Brewer4 said: I know. I have my 4 units stacked and I had to put a separator and isolate the H20 to the way top. You can cook an egg on it. Click to expand... sounds like the old HIRD-e86
jcrandall Proud Staff Member Staff member HERE TO HELP YOU! Apr 3, 2005 11,054 456 Central Michigan Jul 8, 2007 #6 Works great for charging my xbox 360 controllers!
