Have a single Hopper coming. I see that there are two USB ports on the rear. Can I connect both my EHD's and have them both powered up or is it still one at a time? Thanks
Thanks navychop. So is there an additional menu option that comes up when you want to archive a program that allows you to to pick one or the other to archive to?Yes. Or you can connect a USB hub.
KKlare I still don't know if I have an answer. I do NOT want to run a hub. I just want to plug my first EHD in the USB port. Then plug the second EHD in the other rear USB port. Power both of them on from their own ps. Will the Hopper see both?I have run 3 transfer streams at once using only 1 rear connector to an unpowered 4-way hub.
Unlike the 722, you can have more than 1 powered on the hub and it works and distinguishes them.
The transfers can go to any of 3. The viewing/deleting can only access the "first" 2.
Do not depend on the hub powering your drive--that asks too much. Unless it is powered.
-Ken
Ken, you seriously need to start speaking English.The HUB was to show that you do not need to use all 3 built-in ports. You can share any one (or more) of them externally.
I bring one of the rear ports up front via the hub to make for easy plugging to any one/two/three of 11 USB cables.
I generally use the front port for one-at-time loading and the hub for the often used drives.
Then I plug in the supplies needed. You cannot do this on the 722 series.
-Ken
Not that many quirks. HAVE FUN!!!!!Now, I'm off to learn all the wonderful quirks of the Hopper system!
Limited time offer
