Is it possible to use component with optical from my 722k straight to my TV while also having an HDMI to an Xbox One (not turned on) and still get picture and audio?
Based off of that answer here is my second scenario:
Having it hooked up the same way as mentioned above, would it be possible to receive picture and audio while the Xbox One is turned on?
Basically my questions is, can the 722k send signal through multiple outlets at once and still be able to output picture and audio.
Reason being is, I want to use the Xbox One as a passthrough to take advantages of the console but when I don't want the Xbox One on I want to be able to watch the 722k separately(with the Xbox One off).
Unless you can think of a better way of achieving this please offer up suggestions or if this is even possible. I know my PS3 was capable of sending multiple signals.
(my planned set up is Dishnet(HDMI) to xbox; xbo
HDMI) to Denon receiver; devon receiver(HDMI) to TV)
Additonal set up: (Dishnet(component) to TV; Dishnet(optical) to TV)
Thanks in advance. Hope this makes sense because it does in my head . : /
