i have an oval direct tv dish it is 21 X 37, it says direct tv on it and nothing else. question is can i put a dp plus hd 3 head lnb on it, will the lnb adapter mount up with out mods. i don't have the adapter to check the fit.
jerryez said:Thanks boba, he will not be back. There are no stupid questions, only stupid answers.
How many times does this stupid question have to be answered, can't anyone use the search function. Only the Directv 18" round dish can be substituted for a DISH 300 dish the others are not interchangable.
The current WorldDirect dish is 24x36; maybe it is an older version. I wonder if this dish is an AK/HI dish or maybe an DIRECTV LA dish.
In any event, a DISH Network LNB will not mount up without major modifications to the arm and I'd guess that the performance would be less than optimal for a three-slot LNB.
You say "ghetto rig", I say "major modifications".You have to ghetto rig something
You are assuming too much. DIRECTV no longer broadcasts conventional programming from the 110W slot (and I suspect they may be at risk of losing their license to do so).i may be wrong but i do believe the dishes would be the same dimensions for various dishes in order to get the correct focal point for signals.
right now D* has some channels that are "warming" the satellite...other than the "test" channel for a reciever to see if they are locking the sat the rest are not avaiulableDIRECTV no longer broadcasts conventional programming from the 110W slot (and I suspect they may be at risk of losing their license to do so).
I know D* has had rumours of moving the Int'l channels off 95W and to 110...but dont know how they'll do that
using 7 TP's right now on 95
only 3 available on 110![]()
Limited time offer
