Using an External Hard Drive with the Hopper is horrible. The transfer rate is about as slow as molasses in Winter Time. Couldn't the so called "Greatest Receiver Ever" have been designed with a USB 3.0 port
Now that you have added context to your post I don't see you as a troll any longer. You can still transfer, unattended, so that makes it a lot less worrisome. You've got 10 days just do it, but not all of it at one time.I don't appreciate being called a Troll. I like my Hopper ... my original Hopper failed and I only have 10 days to send it back. So, that's the only reason I care how long it takes to transfer to an external HD. Otherwise, I could care less.
Perhaps you should have explained that in your original post instead of making an arbitrary comment.
Yes ... maybe so. I apologize if anyone was offended. It would be nice though (in the case that the Hopper has to be replaced) if we could just hook a USB cable between them and select "transfer all". Avoiding the expense of paying $150 or more for an external HD.
I still haven't seen the official change in what is supported. Last I saw it is still 2 TB, but obviously can work with 3 TB. Remember, the difference in supported, and workable is what Dish will actually help further with.The Hopper will support a 3 tb ehd. I have 1 on each of my HWSs.
Not cost effectively. The chipset only supports USB2. None of the Broadcom SoCs are great USB performers. Wish Dish would enable the eSata port.Couldn't the so called "Greatest Receiver Ever" have been designed with a USB 3.0 port
Limited time offer
