I want to setup my HTPC with multiple tuners (two). I already have a Twinhan 102G, and I've been reading that to get multiples to work, I need to get tuners from different manufacturers.
Could someone please tell me if skystar 2 would work? And if so, which version? I believe that the latest version of ss2 is 2.6D, has anyone tested this with the Twinhan? If not whats the best tuner to get?
I want to setup my HTPC to be able to watch 2 different channels in 2 different rooms.
Thanks!
Skystar would work…but the latest version does not have "blind scan" which would be nice since Twinhan does not have it either, SkyStar 1 ver 2.3 has "blind scan"...I do not know where you are going to get one...but for almost the same cost you can get the card below…has all the features I would want…I might get it for my second card since SkyStar 2 does not have "blind scan". BTW I never tested either SkyStar 2 or AVerMedia AverTV DVB-S Pro or Twinhan, so you can take my advice with caution, but if you are set on buying a SkyStar 2 ver 2.6C I am willing to depart with mine, shipping is on me if you are in located in the USA.
AVerMedia AVerTV DVB-S Pro Internal PCI Digital Satellite TV Tuner Card, 75 Ohm Coaxial
TV Antenna/Composite/S-Video/Audio In/FM, Remote included
$119.00 GST Inclusive
Features
AVerTV DVB-S Pro
Watch Digital Satellite TV and Listen to Radio on Desktop !
"AVerTV DVB-S Pro " is a Digital Satellite Receiver Card, which allows you to access most worldwide digital satellite TV channels beyond geographic boundary on your desktop with sharp picture quality. To fulfill a variety of customers' needs, AVerMedia DVB-S Pro offers "Satellite Internet Access" service, an exciting feature to enjoy the fun of surfing on web at high download speed on your desktop. What is more, another value-added function is that AVerMedia DVB-S Pro can support Windows XP Media Center Edition (MCE) operating system to further catch up the wave of digital home entertainment.
With AVerMedia DVB-S Pro, you can not only record and save TV programs directly to your PC in MPEG-2 format but also even hook it up to your home video entertainment system with the additional AV and S-video input. Moreover, a fully featured infrared remote control is included to make you to access each feature with ease.
Comparison Table for AVerMedia DVB-S Series
Product Name AVerTV DVB-S Pro AVerTV DVB-S Hybrid+FM
DVB-S O O
Analog TV X PAL / SECAM / NTSC
Stereo Sound O O
Internet via Satellite O O
Product Image
Software Features – AVerTV 6
* Personal Video Recorder (PVR)
o TimeShift
o Schedule Recording into MPEG-1/2 formats
* Channel Management
o Fast Channel Switching and Scanning
o PIP (Picture-in-Picture) / POP (Picture-on-picture)
o 16-Channel Preview
* Complete Channel Scan Capability
o Blind-Scan
It can make up the limitation of default channel frequency and therefore allows you to search more updated channels.
o Easy to Import and Scan All Channel
You can import any satellite channel data file (.sdx) downloaded from the Internet into the application and then scan the stored frequencies for the latest digital satellite programs.
* "sdx" is the format of satellite channel data file
File Management
* Multi-User Settings
* Channel Remapping
Power Management
* Auto Power Off
* Wake-up from S3 (Stand By) /S4 (Hibernate) mode
* Sleep Timer
Quality Management
* Video Quality Enhancement
* Audio Effect Adjustment
* Internet via Satellite
* Worldwide analog TV Access (Optional)
* Free-to-air DVB-S
* FM radio (Optional)
* Worldwide Stereo sound
* Windows XP MCE 2005 Compliant (DVB-S only)
* Highest quality silicon TV tuner
* 32/64-Bit Support
* Input Signal
o 75 ? TV Antenna Input
o S-Video
o Composite (RCA)
o Audio In (L/R)
o Remote Sensor
o FM Radio Antenna Input
* Dimension
o 165mm x 64.41mm (Low Profile)
* 256 MB RAM or above
* PCI 2.1 compatible slot
* VGA card supports DirectX 9.0c
* Digital Satellite Dish
* Sound card
* Windows® 2000/XP
* Windows® XP MCE 2005 (DVB-S only)
SDTV
* Intel Pentium® 4 2.4G Hz (Hyper-Threading)
* Intel Pentium® 4 2.8GHz for TimeShift and Record in MPEG-2
* AMD AthlonXP® 2400+
HDTV
* Intel Pentium® 4 2.8GHz for Record in MPEG-2
* Intel Pentium® 4 3.0GHz for TimeShift
* VGA card supports HDTV, DxVA and with 128MB or above
* HDTV will only function when the TV signal is in HDTV format
** The DVB-S mentioned here means standard DVB-S TV system, not DVB-S2.
* AVerTV DVB-S Tuner Card
* Quick Installation Guide
* Installation CD
* Remote Control (Batteries Included)
* Infrared Sensor Cable
* FM Radio Antenna (Optional)
* All-in-One Cable
Model
Brand
AverMedia
Warranty
1 Year Manufacturer's return to base
Manufacturer's Link
http://www.i-tech.com.au/products/235_AVerMedia_AVerTV_DVB_S_Pro_Internal.aspx
