Hello Guys,
I need some help with getting my Multi-Switch to work right! I have tried using two new 5x8 Multi-Switches. The first switch is:
SVI 5x8 Trunk Line, has 24VDC Power
LNB-A, 13VDC/0kHz
LNB-A, 18VDC/0kHz
LNB-B, 13VDC/22kHz
LNB-B, 18VDC/22kHz
The other (TERK) has the same setup.
I am using 3ea LNBF's. I am using four cables coming from the three dishes.
1ea. C-Band GeosatPro (Dual)
2ea. GeosatPro SL1PLL
I am using the GeosatPro MicroHD Box, which is (GREAT)!
The problem is, no matter how I hook up the four cables to the multi-Switch, I can't get one of the SL1PLL LNB's to both pick-up the Horizontal side on both dishes. It's either (Horizontal) on one and (Vertical) on the other. Before I changed out the LNBF's on the Ku side I was using the dual GeosatPro LNB's. I get the same problem with either LNBF used. I would appreciate some of your experienced help! I hope it is something silly I am not doing or some setting I have wrong. Thanks! Mean while, I will keep looking for answers!
LNB-A, 13VDC/0kHz
LNB-A, 18VDC/0kHz
LNB-B, 13VDC/22kHz
LNB-B, 18VDC/22kHz
