Using TV1 remote as duplicate TV2 remote on 622 | SatelliteGuys.US
jkinghome
22
I use a Harmony remote to control my 622 TV1 output. How can I program my Dish TV1 as a duplicate TV2 remote? Is this possible?
Thanks!
The TV2 remote is both UHF and IR. The IR portion is for auxillary devices. The UHF controls TV2, so TV1 which has NO UHF capability CANNOT control TV2. You can buy another UHF remote.
Does your TV1 remove have a removable key? If so, you can change the key to use a TV2 remote key... and make sure the satellite address is programed to the same as your other TV2 remote... and off you go.
The TV1 remote that ships with the 622 is a #5.3 IR only, so if your plan is to use that remote elseware in the house you will not be able to. It seems crazy to me that they don't send 2 #6.3 IR/UHF remotes with the 622. What do they save $0.50?
Dish 1000 install -- rain delay???
Picture Quality
