I just finished setting up and logging all of the TPs on all of the sats I can see on my C-Band setup on Thursday last. Predictably, I go off for the weekend, come back, and the V-Box throws a consistent Er2 error when I try to move the dish.
Oddly, I can move the dish with no problem in both directions using the signal quality menu on my SV-8000HD, but the V-Box no longer moves the dish using the pre-programmed positions I set up for each satellite that were moving the dish every time I chose a new satellite through the receiver.
Hopefully the description here makes sense. The fact that it will move manually in both directions suggests to me that there is no hardware issue with the actuator (which is only three weeks old) or the wiring. The actuator can be moved either direction through the menu on the receiver. However, the Er2 error stays on the readout of the V-Box constantly, and the V-Box no longer moves to saved positions.
In essence, I can move the actuator using the receiver manually, but the V-Box will not automagically move to the saved motor positions that worked fine before I took the kids to Disneyland.
Any ideas appreciated. Finding Qubo for my 8 year old is really difficult without the ability to move to saved positions.
BTW: While at Disneyland I saw several C-Band dishes at Tomorrowland. In order to be futuristic one of the buildings had what I can only describe as a collage of mesh dishes and dish parts artistically arranged on the roof. Heck, it looked like a couple could have been the same as what I have in my backyard.
