VBox DP710 dish mover for c Band | SatelliteGuys.US
Virgil Gomes
49
Hello Everyone,
My parents have a 7.5' dish. I set them up with a Pansat 2500 and a V-Box DP710. The V-Box DP710 is used to move the dish via Disq 1.2 commands from the Pansat 2500. Everythings has been working ok but every so often I need to re-adjust the satellite position. It seen that there is some drift. This takes a while to occur and depends on how manny times the dish is move from satellite to satellite. The drift always occurs in the same direction. I'm not sure if this is a problem with the V-Box or with the Pansat 2500.
Has anyone encountered this problem?
Thank you,
Virgil
