Video Modulator Help! | SatelliteGuys.US
pattyw
4
San Diego
I have a gate with a CCTV camera on it and I want to modulate it to one of my TV's. So it is just one TV and One Camera.
Here is the modulator I just ordered.
Linear 5415 One-Channel Video Modulator
My question is if I can share the coax with Direct TV? Or do I need to run seperate cables. Any input is appreciated!
What DirecTV dish do you have?
Diplexing onto the KaKu signals is difficult at best.
Running a separate cable is the better way to do this.
First question is, as jdspencer wrote, what is your D* setup? If it is a Slimline dish either straight to your receiver or to a multiswitch then to the receiver, the answer is no, they cannot use the same cable. Slimlines go down to 250MHz, and that modulator operates in the 470-806MHz range. If you have a SWM module, yo can just connect it to the OTA port on the SWM and at the outlet use a 2-2150MHz splitter (not a diplexer).
If your dish is just looking at 101, any old pair of diplexers would do.
Adjusting Dish Elevation
just switched but still cant shake comcast
