Videocipher Module in DSR920 | SatelliteGuys.US
ChuckBoozer
253
2
South Carolina
Any reason to keep it installed in the unit or is it completely obsolete?
Thought I might remove it to lighten the weight of the receiver...
sometimes the analog channels go into fixed key mode, so it would be handy to keep it in there or..... you could stash secret stuff from your wife! she would never look there:D
Thanks for the replies. I will probably just leave it be - doesn't weigh enough to make much of a difference any way.
Just need to find another place for my "secret stash"... ;)
there are only 3 VCII channels left
ESPN & ESPN2 which are for commercial use only
Weather CHannel
My 920 still has it's VCII box in it, and it came in handy a couple weeks ago, when the C3-13 Weather Channel went fixed-key for a few days. When there's no more VCII datastream, then I'll take it out. :)
Which 4DTV Sat comes in the strongest
Dual lnb mounting
