viewsat extreme, parental pin ???? | SatelliteGuys.US
dicknada
3
Hi everyone, I'm new to the site. I live in Halifax, Nova Scotia. I just set up a Viewsat Extreme. I was deleting a few stations and the receiver frooze up. I powered it off and on and when it came back up, the receiver asked for a parental pin. The only pin I have is 0000 and it no longer works. Any advice would be greatly appreciated.
Cheers,
Dick
Did you chnage the PIN #?
What's your setup? (Dish size, LNB, motor if applicable, etc)
if all else fails, reload factory software on it. That usually resets everything :)
Hey Iceberg
I have an ExpressVu 20 dish and two LNBF Dual D-Channel Feeds and an Echo SW21 Switch,
I did not switch my pin. I have been trying to reload the software, but It is not working.
I have Loader v1, VS2000_NEWOSD_EXTREME_2061_factory_bin.
Is this the right software? Can't seem to get it down my comport.
Thanks for your response.
d.
yep thats the factory software...of course you aint gonna get much with a 20" dish. For true FTA, you need at least a 30" dish and a different LNB
what were you looking to pick up?
echostar
It was working pretty well on echostar 9 and 7. I had it set up on 263magnetic, 21 elevetion and skew 126. I was getting a good signal, but every time I changed channels, I had to turn it on and off!!! Any comments on that?
I figured if I reprogrammed I would be alright. I think I'll try it on a different computer. My comports do diddley.
I might move to a 30" dish to get more satelites.
Cheers
d.
yep...thats what I figured...when someone "loses" their PIN #, 99% of the time they're stealing
we have a No Hack Talk rule here...you steal, I ban. Plain and simple.
Nice way for me to start the morning...1st thrread I see becomes a new notch on the "ban belt"
closed
banned
Pete has his "no halk talk" picture...I have mine now (new one)
Ha Ha!
2006 Baseball on FTA Guide
