Viewsat Pin Code reset? | SatelliteGuys.US
998ccc
13
Northern Ca.
Hello all. I bought a fairly nice Viewsat VS 2000 Ultra used off of fleabay and quickly found that the pin code had been changed during its previous life. So far, there has been no response from the seller, so is there a way to reset the pin back to the factory standard 0000?
Thanks.
998ccc
3570 and 0937 are suppose to be the master pins for the Viewsat.
You should be able to use one of those to log in and change the pin.
Need help with Manhattan 1933
Openbox S11
