Vip 211 | SatelliteGuys.US
Vip 211
Trouthead
243
8
Rockies
Dumb question. I want to change from a 811 to a 211. Presently I run one HDTV and a SD TV in another room. I must watch the same broadcast on both TV as there is only one tuner.
Does the 211 work the same way. Can I run two tvs one HD, and one SD at the same time with the same boradcast.
One difference between the two receivers that usually pisses off a lot of customers; no UHF remote. It's a PITA if you have a projector or, in your case, you want to change channels from a remote location
Buffalo Sabres games in NC
625 Fast forward is slow motion
