VIP 622 and The Home Set Up | SatelliteGuys.US
jeramyaupton
Northwest Arkansas
Hello friends! New guy here. I have some experience installing and pointing and such but this problem baffles me. I have a TurboHD branded dish 1000 satellite with the three dishpro LNBs. As I pointed and peaked outside directly connected to the dish all worked well. When i moved my VIP 622 receiver inside, I couldn't get a signal. I checked my connections outside and determined that it maybe the "splitter" being used to direct data throughout my home. I assumed I needed a DC pass through style splitter to do it, so I left my tv/receiver on and went to my local satellite supply store. I cam back and the receiver is off and won't turn back on. What gives? Did I damage it?
By your post, I am assuming that this is a 1000 dish with three dual lnbs? Not one integrated LNB? If it has bracket on the front of the dish that looks like a "W", then you have a 1000 dish and need to run three lines off the dish into a switch. If you use a 34 switch, you need two lines to the 622, a 44 switch with a power inserter on port one would only require one line to the receiver and a seperator at the receiver. If you have a 1000.2 dish w/ the integrated LNB, (three round eyes on one LNB), then one line to the 622 with seperator at receiver. Check switch after install. Watch TV!
Question about 722K
echostar 6.3 remote and sony bd570
