Vip 622 installation | SatelliteGuys.US
gonchin
mexico
Hi:I need some help installing a VIP 622 with two dishes (110-129) can somebody tell me what type of lnb and switch I need to run the 2 coax cable to sat 1 and sat 2 inputs in the receiver? Thanks
I dont want to sound as if I am questioning plans BUT.....
if you want to get all the channels you will need to see 3 orbital location not just two (110/119/129 or 61.5) It depends on where you live as your locals will more than likely be on one or the other. (129 or 61.5)
also...since you have a VIP622 AND you have a DPP dish/lnbs and or DPP 33 or DPP44 switch, you will only need to run one wire to the reciever and use a DPP seperator.
i hope some of that was helpful
I, and a lot of others, have a D500 that has a third LNB input on the main LNB, and you daisy-chain the 129 or 61.5 wing dish's feed into that. You can use a D300 or a D500 with a single DPP LNB for a wing dish. Or if your locals are on 129, and you have full LOS, just use a 1000.2 dish/LNB that spots all three birds.
No multiswitch needed in either case; just a separator (not splitter) on the back of the 622.
Rockford Il. HD locals?
Tragic "BRIDGES" TV News
