VIP-722 2nd Tuner Control | SatelliteGuys.US
idzerd
I don't know if this has been asked before, but can the 2nd tuner on the VIP-722 be changed from UHF control to IR Control? I have an a/v distribution system with keypads. The system both learns/controls and passes IR.
Obviously, tuner 1 is controlled by the keypad or IR pass-through. But I don't know if I can change tuner 2 to be controlled by a distinct IR control.
Thanks,
idzerd
It cannot at this time. It has been talked about in the past (I believe on a technical chat), but so far we haven't seen it. I know many would like this for use with SlingBox and other devices (like you are talking about). Hopefully they actually do this in the future
Low signal from 110 sat
Voom Channels Down
