vip 722 | SatelliteGuys.US
vip 722
So EHD will work from 722 to Hopper, but not Hopper to 722?
Since the Hopper went to the new GUI some time back I don’t think it will work either way. I don’t have a 722 to test it so I can’t prove it either way. It may well work. I guess the OP could try it to prove it either way. It should be said that the Hopper and 722 must be on the same account number.
Reactions: charlesrshell
My EHDs moved from 722 to HWS and they worked. They also still worked when I moved them to my Hopper 3s. Not sure if moving EHDs back to 722 will work. I would think they should. Like you, I think the OP could try.
Reactions: TheKrell
Can I take the external drive from a hopper and read it from a vip 722?
Are both receivers on the same account?
If not - NO WAY!
If they are - it might, but should do no harm if you don't let it reformat the EHD.
Give it a try and let us know.
BTY, I don't think GUI or old interface should effect reading an EHD, but that's just my guess.
