VIP622 receiver new spontaneous reboot issue... | SatelliteGuys.US
primestar31
14,733
17,045
Beta Omicron Delta III
I recently made a couple changes to my Dish setup. I installed a 1000.2 EA dish that only can see 61.5 and 72.5 which replaces the separate dishes I had with a spilt-arc. I have a DPP44 switch out at the dish, and did have 2 coax cables coming into the house from ports 1 & 2 going to tuners 1 & 2. Cable 1 goes to the DPP44 power booster first, then up to tuner 1. The signal numbers from the transponder list match the levels required for my area for the key transponders. That's the 1st change I made, and it ran like that for a couple days just fine as far as I know, with no spurious reboots. Unless some occurred when I wasn't around.
I then consolidated the coax cabling coming into the house a few days later. I removed cable #2 from the switch, and from tuner #2. I installed a dish separator on cable #1 (actually at the end of the coax jumper coming from the power booster for the DPP44), and attached each leg from the separator outputs to tuner 1 & 2 inputs. I then ran a check-switch, and it found the separator and all appeared to be well.
Today however, the receiver has rebooted twice for sure that I know of. Once this morning, and once about 1.5 hours ago. I was not watching it at either time, I was watching my FTA receiver, but heard the reboot and the fan kick on and off. I switched over to it, and it did the 5 minute signal thing, and then did the 10 minute FULL guide reload (both reboot times it did the full guide reload. That doesn't typically happen on a regular signal loss reboot, at least I don't remember it happening?).
So, I don't know what's up. Did my changes cause this, is it a fluke, is my internal harddrive going bad yet again? I've had spontaneous reboots before from signal loses during thunder storms, but that's not happening today. Since I wasn't watching it at the time, I don't know if there was a signal loss screen just before today's reboots either. OH! I checked the temp of the drive in diags, and the high is 127 degrees, low at 95 (it's been 95+ here for days)
Anybody got any ideas?
very unlikely the changes provoked the issue unless there MAYBE grounding issues? still that is a huge reach IMHO. but you can always Drop the cables to verify your sat installation is not causing the reboot. also if you have another receiver you can swap locations with? that would tell as well.
Is there a reason for the DPP44 the 1000.2 can run 3 dual tuner receivers without an external switch? Does port one of separator go to tuner 1 of the receiver?
The DPP44 was needed when I had 4 separate dishes spread out in an arc to aim at the individual sats because of tree trouble. Now I'm down to the one EA dish, and I fed 72.5 lnb output, into input port 1 DPP44, and 61.5 lnb output into port 2 DPP44. Like it shows in the install book. Because of my wiring hub being at the central dish area, it's just easier to leave it that way. Yes, port one of the separator goes to tuner 1.
We had a massive thunderstorm this morning since about 5:30am, until 9:30am. The receiver lost signal for a bit during the worst of it, and it did NOT reboot!
Just my two cents. If it was me I'd bypass the DPP44 and its power inserter, since the 1000.2 will work just fine without it.
Can it still be used with a single cable, and the dish separator on the back of the receiver? I would assume so, since it's a DPP lnb, but I'm not positive. I do have some 3ghz waterproof barrel connectors, and can jump the wire from port 1 of the 1000.2 dish, to the cable coming into the house from the wiring hub area.
My 622 has been flaky the past month or so as well. Might reboot itself 3 or 4 times a week (just did, matter of fact...picture froze right before it happened). No storms or other weather anomalies around and nothing's been touched.
(BTW, I've had a USB fan blowing out on the side of it ever since somebody suggested that eons ago)
Yes indeedy. Without the power inserter.
Cinemax On-Demand Content
Flat Cable Adapter
