I have the VIP722 Duo.
It looks like the coax out on the back labeled "home distribution" will feed out to every room where I want a TV. I will have my main TV in the living room and I will also have a TV in the kitchen, bedroom and guest bedroom. I will use the RCA output labeled "TV1" for my main room and I will feed the other rooms from the coax out. Am I correct that whoever has the 2nd remote will control the TV channels fed from coax out in the kitchen and bedrooms, but it will not change my main output in the living room because it is fed from the output 1 RCAs? I'm trying to figure out how 1 coax out will work when the duo has 2 outputs.
