Vip722and CATV | SatelliteGuys.US
Vip722and CATV
KenM37
20
Does the connection for antenna/cable input just for digital signals? If I hook up the cable for my cable TV to that input will will it distribute it to the in-home distribution output?
KenM
No, the 722 does not have a qam tuner which cable uses, nor does it allow the cable signal to pass through the receiver via the rf connections. You can use a simple splitter in reverse (as a combiner) to combine the cable and rf outs and run that through your distribution network.
Again let me apologize for being so dumb. I looked at the link and still can't figure out what a Qbox is? What does it do? Does it convert something to something else? Where do I buy one? I've seen reference to "Qbox support" but a google search shows something that attaches to my computer via USB.
Need Some Info....
RF remote for VIP622 drains batteries fast.
