Vip722k - OTA recording glitch | SatelliteGuys.US
lparsons21
9,925
8,073
Herrin, IL 62948
Last night I was recording off OTA of the Philanthropist. All was good until right at the 30 minute mark, then it decided the show was over. I restarted the show from the beginning and every time it hit that mark, it ended the recording.
I've had this happen twice. The first time I just pretty much ignored it, but last night it was there again.
Any ideas, or is this a known issue?
thanks
Most common cause reported is deleting from your EHD while recording.
Do you have software L654 yet?
Im hoping this issue will be cured. Sometimes when I delete from the internal drive a tuner freezes and I have to change the channel
No. I'm still on L652.
I haven't had your issue yet, but I have had PIP just go nuts sometimes, usually a power off/on cycle cures that.
912 recording problem
Wiring Diagram Help
