Vip722K Remote IR/UHF Switch Issue | SatelliteGuys.US
jcart
38
I apologize in advance if this has already been covered. I've been searching the forums for this issue and can't find anything. I'm trying to follow the instructions for switching remote 2 to IR but I'm having difficulty. It says to switch the remote to IR, select the System Info button on the front panel, and select the record button. When I do that it just switches the remote 1 address from 1 to 15 instead of switching remote 2 to IR. Am I skipping a step here?:confused:
So the IR switch is to use remote 2 on TV1? That's not what i wanted to hear. I have two IR universal remotes that I want to use and I was hoping to use remote 2 too program them.
what model number remote do you have?
21.0 is switched inside the battery cover, 6.4 is switched with correct key tab
301/311 vs. 211K
