Virtual Joey Update?? | SatelliteGuys.US
jeffreymabq
8
New Mexico
There are only a couple of threads (that I could find anyway) on the Virtual Joey app for LG Tvs. I am getting ready to replace the bedroom TV, and would like a one-stop solution. I saw a thread once that was a couple pages long and had several different models available for Joey, but now I can only one thread that refers to older TVs. There's also the question of the 5800 series (the 2014 models that are NOT webOS) being compatible floating out there.
Does anyone have a list of what TVS are compatible. I really don't want to make the big purchase for nothing. Thanks!
jeffreymabq,
The LGTV's that are compatible for the Virtual Joey are;
LN5700; 32/42/47/50/55/60
LA6200; 42/47/50/55/60
LA6900; 47/50/55
LA7400; 47/55/60
LA8600; 55/60
LA9650; 65/55
It will only be compatible using the Sony Play Station 3.
I just posted a question to the Dish support thread, since I can't find any manufacturer named Netcast, and these models are the same model numbers as LG sets.
https://support.dish.com/viewtopic.php?f=9&t=10556&p=59470 (reproduced below)
LG TVs have NetCast software on them (http://www.lg.com/us/netcast/index.jsp), particularly the models you listed as "NetCast":
LG LB5800 http://www.lg.com/us/tvs/lg-32LB5800-led-tv (comes in the same sizes listed, 32/39/42/47)
LG LB6100 http://www.lg.com/us/support-product/lg-47LB6100 (comes in same size listed, 47/50/55/60)
LG LB6190 http://www.lg.com/us/tvs/lg-65LB6190-led-tv
Wireless Joey Receiving distance?
DISH Anywhere upgrade problems
