VisionPlus software | SatelliteGuys.US
VisionPlus software
PKII
791
19
WV
Anyone know how to add a Satellite not listed in the Software for VisionPlus. I have the newest version. :confused: I am using a TwinhanDTV Sat DVB s digital Satellite TV card 102G any suggestions on another type of software other than VisionPlus?
'any suggestions on another type of software other than VisionPlus?
Reply With Quote"
It's not free and at $99, it might be out of your budget, but Tsreader is a great piece of software that supports a wide variety of hardware, including some OTA atsc cards. I purchased a copy and I don't regret it one bit. Anyway, if this is out of your budget then check out some of the free programs that Cascade mentioned.
As for the stock twinhan software, I don't think most people even bother to install it as third party software will give you much greater capabilities.
Traxis 4500
Holiday FTA Tinkering, Need Advice
